Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 02-29-2008, 01:44 PM
nowuwant2nome nowuwant2nome is offline
Rail Replacement..What Is It
Okay,
I am having problems with my 97' and have seen posts here about a conduit with the rail replacement (recall). Can someone explain what this is and what happens if you don't have the replacement done. Maybe the symptoms my car is experiencing are due to this.
0 PSI
Oil Leak
Radaitor Leak
Low Coolant
Coolant looks like soapy foam
Thanks
Old 02-29-2008, 02:37 PM
ghutchin ghutchin is offline
Re: Rail Replacement..What Is It
This is not your issue.
Old 03-01-2008, 10:21 PM
back2life's Avatar
back2life back2life is offline
rail replacement is for the the fuel rail. changing from plastic to metal due to excessive fires under the hood!
Old 03-02-2008, 10:27 AM
More specifically the original rail was some sort of nylon composite that over time would eventually crack and cause fuel leaks. The fuel leaks did not affect drive ability except for the leaking fuel in the engine bay which could lead to fire. Your issues would be a result of this issue. However, if you still have the nylon lines it is recommended that you get them replaced. The dealer should do it for free.
