Old 02-25-2003, 03:39 PM
Modelcargarage's Avatar
Modelcargarage Modelcargarage is offline
Send a message via AIM to Modelcargarage
Olds 4-4-2
I just started my olds 442 and i went to put my clear coat on it and the paint cracked so i have to sand it but last time i sanded a car and the resanded it it came out with many scratches all over the body making it look even worse ! whats my problem here?
Old 02-25-2003, 03:49 PM
Asmenoth's Avatar
Asmenoth Asmenoth is offline
AF Premium User
Sounds like you are using a sandpaper with too course a grit. After sanding off the paint go back with progresivly finer grades of sandpaper, just like if you were rubbing out paint except you shouldn't have to use 3000-12000 grit for this. I have Tamiya's pack of fine grit sandpapper, 1 1300 2 1500 and 2 2000 grit papers, and some of their rubbing compound. After using those, primer it and look for scratches. If they are there, start over. Once the surface is appears smooth after priming...you should be good to go.
Do you know how fast you were going son?
No Officer, the speedometer only goes up to 85.
Old 02-25-2003, 03:52 PM
Geez Geez is offline
Interesting you should post this....
I was in the hobbyshop yesterday, and reallized exactly what kind of model I would want to do... then promptly forgot it until now.
Does anybody have any info on an 1971 Olds 442 convertible kit? Gorgeous, rare car!
Recently completed:
Tamiya Mobil 1 NSX
On the go full time:
Tamiya Porsche 911 GT1
On the shelf to start:
Jagermeister 155 Alfa Romeo
Ferrari F40
Old 02-25-2003, 03:53 PM
thanks
thanks ill try that thanks for replying see you later
MCG
Old 02-25-2003, 03:57 PM
it is beautiful
thats car is gorgeous it was a valentines present from my mom and its very nice but its a hartop made by revell very nice car though
Old 02-25-2003, 03:58 PM
Re: it is beautiful
What year?
Recently completed:
Tamiya Mobil 1 NSX
Ferrari F40
Old 02-25-2003, 04:12 PM
a 69!
2.4 blowing black smoke cr_rider Mighty Max 5 12-31-2010 02:56 PM
97 F150 4.2 Roaring PLEASE HELP stanley24538 F Series 7 10-25-2010 07:46 PM
Nissan Quest V6 to 2.4 ltr 4 cylinder swap Scraped Knuckles Quest | Presage | Serena 4 02-20-2009 08:59 AM
94 olds 98 cylinders 2 4 6 not firing brokanic Ninety Eight 12 09-17-2007 02:11 AM
91 olds cutlass calais 2.3 quad 4 info krisntn Cutlass Series 1 05-09-2004 04:21 PM
