Old 02-28-2008, 09:05 PM
readallen readallen is offline
the list
I have a 96 jimmy 4.3L W code 4WD AT 4 door
the list
1.when I turn on the turn signal the volts drops with the flashing
2. sometimes putting it in reverse will drain the volts
3. sometimes pressing the brakes will also drain the volts
4. the blower motor will drain the volts down
these are most pronounces when raining
5. the power seat does not work
6. the doom light was staying on all the time, have not checked recently -took the bulb out
7. the light by the drivers shins stays on all the time
8. rear wiper worked, stoped working and just recently started working again
9. 3rd brake light does not work
10. pas. side rear window stopped working
11. rear glass hatch release pops when-
I put the fuse in
randomly when nothing is being done
pressing the release button -but not always works
when pressing the lock or unlock button
when opening the drivers door, usually just lifting the handle will do it
12. hinge is cracking free from the vehicle- drivers door upper hinge
13. 4wd doesn't work - more on that later
14. more that I'm not remembering at the moment
AND just did the 98 jeep grand steering shaft swap, one problem fixed/amazing difference
need help or a different vehicle
Old 03-04-2008, 05:42 PM
Re: the list
ok'
Old 03-26-2008, 08:58 PM
Unhappy any help
any help
Old 06-30-2008, 10:50 AM
Schrade Schrade is offline
Re: the list
Looks like everybody's jumpin' in huh?
Where are ya' on repairs now?
Old 06-30-2008, 12:33 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: the list
the list
I put the fuse in
OK, For items 1 - 4. It sounds like your altenator is going bad. Check to see if you have around 14 volts when ideling.
For items 6 - 7. Check your door pins to ensure that they are operating properly. Door Pin switch should read open in the inward position and closed in a outward position. Check your rear glass switch as well. Anyone of them can cause your dome and floor lights to stay on.
Item 10. Open door panel and remove the power connector from the window motor. se volt meter and test the 2 pins inside the connector for 12volts when operating the window switch. Ensure that the ignition switch is in the on or start position. If voltage is present. Replace window motor. If no voltage test and operate from the dirver side main control window switch. Chech to ensure that the window lock switch is in the normal position and test for voltage.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
