| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
turbo seal/gasket
will a turbo seal make my car smoke?
kosei black powdercoated 16'' rims,hyoshi muffler,removed smaller honeycomb in maf,ngk wires and plugs,luk clutch and pressure plate,stock flywheel,traction t/a bfgoodrich tires,silverstar ultra headlights |
Re: turbo seal/gasket
Yes, oil can leak into your intercooler pipes or into your exhaust.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
okay,got the turbo off,and the fel-pro kit from advance didn't come with a new o-ring,do i have to replace this piece?
will be posting a pic soon!!!!
What seals are you referring to? If the seals inside the turbo are leaking then yes your car will smoke. If the gaskets are leaking then no it shouldn't be smoking.
The way you worded your original post sounded like you were talking about the seals inside the turbo. But now Im starting to think you are talking about the gaskets.
oh sorry,my bad,the seals
The seals inside the turbo?
yeah
You will have to have the turbo rebuild to fix those. Or you could rebuild it yourself and send it off to get balanced.
dealer?
Im sure you would just have to buy a new turbo at the dealer. I doubt they repair them. If they do it would be an ASS of money.
how about just upgrading to 16g,would i have to get a certain mani. for it?
instead of getting 14b repaired and costing ALOT of money,i could go ahead and upgrade and not worry about anything.
The 16g will be a direct replacment. You shouldn't have to change anything.
sweet,all feed lines and interc. pipe from turbo fit exactly,the maf on the inlet is big enough right,cause i found one on ebay for like 40 or something with little shaft play,good?
If it is only $40 bucks then its probably not a good idea. That "little" bit of shaft play is probably alot, lol.
Caleb vanilla gorilla '99 Spyder 2.4 5-speed - Red/black,14b,slow '96 Eclipse GST 5-speed - Paint www.myspace.com/ballsoutperformance |
yeah,the turbo specialist i took it too said he would charge me $340 to rebuild it and balance it,so i bought a new one for $190,he said there was a little surface rust inside.
http://evergreenturbo.com/
