Go Back   Automotive Forums Car Chat > Pontiac > Sunbird/J2000/2000 Sunbird
Old 02-28-2008, 08:18 PM
pfei007 pfei007 is offline
where is the Neutral Safety Switch located on 94 Sunbird?
Old 02-28-2008, 08:31 PM
|WYG|SS |WYG|SS is offline
Re: where is the Neutral Safety Switch located on 94 Sunbird?
the neutral saftey switch is located on top of the transmission, on drivers side, you will see the little arm connected to the shifter going to it, it should look like this with automatic, an this for a manual.
Old 02-28-2008, 09:07 PM
thank you so much!
how can I reach this neutral saftey switch? from inside the car or under the bottom the car?
Old 02-29-2008, 04:39 PM
you should be able to reach it from the top of the engine. their is one bolt connecting the shifter linkage to the saftey switch. and 2 screws holding the switch down.
