Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 02-28-2008, 03:07 PM
tysmith14 tysmith14 is offline
Heater/AC Blower motor
I have a 2003 expedition and recently have been having problems with the blower. It will sometimes be on the low setting and blow hi. or sometimes it works as it should. If it is blowing HI and I manually press the switch to lower the blower it will not lower, however if i press and hold the switch it will go down. I need some help here, do you think it is the switch or the blower resistor?
Thanks in advance!
Old 02-28-2008, 04:16 PM
Davescort97 Davescort97 is offline
Escort guy
Re: Heater/AC Blower motor
I suspect it is the switch. Holding the swich down wouldn't lower the air speed if the resistors were bad. Gotta go with the switch. Anybody?
Old 02-28-2008, 05:02 PM
So here is my next question, if it is the switch how hard is it to switch those out? Does that plastic trim pop off in some sort of way and then just a electrical connection on the switch?
Thanks for the quick response.
