Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-28-2008, 10:00 AM
91talondsm 91talondsm is offline
what light is this coming on? 91 talon tsi
theres a yellow light that looks like a plug maybe , that comes on next to my check engine light,like i said it lights up yellow the pic is like square with lines up and down in the square and has a lip on top of the square. ive checked my chiltons book and it doesnt show it. its not the check engine light.
550cc's,walbro 255fp,stock 14b at 15psi,palm m130 with mmcd logging software,2 1/2in. down pipe to 3in. exhaust, high flow cat.,2g maf with k&n,custom intake,aftermarket boost guage,mbc,6 bolt with 160 compression. in closet:b16ge3 turbo,rochester 680cc inj.
wish list:wideband,headers,1000cc,e85 conversion,dsm link or map,fmic,20g,272 cams,arp head studs,2600 clutch,lsd,keydriver,. 13sec. daily driver goals.
Old 02-28-2008, 10:08 AM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: what light is this coming on? 91 talon tsi
Sounds like your battery light. Check your connections, at the battery first. Then make sure your alternator is charging. Last time mine came on, my alternator was on its way out the door.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 02-28-2008, 10:10 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Battery light is red. Usually yellows are "not that bad", and red is "needs attention. Then why is the CEL yellow?
It sounds like either low coolant. Could also be low windshield washer fluid, but probably the first one. Check all fluids.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-28-2008, 10:27 AM
Thumbs up Re: what light is this coming on? 91 talon tsi
not the battery light, will check all fluids right now. thanks
Old 02-28-2008, 10:55 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
I would bet its the coolant...
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 02-28-2008, 12:32 PM
yep u are right my o.f bottle was empty filled er up and light went off. found out im burping coolent out of it on a hard run. my radiator cap has the red pull tab and just bot it, but the damn thing is hissing a little bit i can hear ,so i guess im not getting a good seal causing the overflow.
love my dsm but if its not 1 thing its another.
Old 02-28-2008, 03:01 PM
JoeShmoe's Avatar
Its not supposed to create a vacuum. It should have a way of breathing, yours doesn't? You replaced your bottle cap, don't know how that will affect your car.
Old 02-28-2008, 03:18 PM
my overflow has a overflow tube, but the rad. cap shouldnt be losing air, that should be under pressure right? the rad. cap is what i hear hissing a little not the o.f bottle thats bubbling over.
Old 03-02-2008, 06:57 PM
Damn yall are right. I don't know what I was thinking. Sorry for steering you in the wrong direction. Mine just came on today too. I'll get to it tomorrow.
94 Talon 1.8L-SOLD
Old 03-03-2008, 06:14 AM
Hooedaddy's Avatar
Hooedaddy Hooedaddy is offline
You might want to compression check you motor. Your coolant shouldn't be pressurized to the point that water will boil over unless your car is over heating. At least that is the idea unless you do indeed have a faulty cap.
There is a possibility that if you have a blown head gasket you can pressurize your coolant with your engine's compression which will lead to forcing water into your overflow and then out of the car.
I know this first hand so you might want to get it checked before you get to far away from home.
2000 Dakota(lots of Mods)/1993 Eclipse & 1993 Talon(currently being modded)
Old 03-03-2008, 06:22 AM
JoeShmoe's Avatar
Sounds good to me.
Old 03-03-2008, 09:58 AM
did compression test it was 155 across the board. i no 164 is new and 121psi is service.only dumping coolant when running it hard for a few pulls threw all gears. i can drive to work normal and race a few people and not lose any coolent.people were saying head gasket about a month back when having same problem,but wasnt that my thermostate gasket was leaking and stopped the problem.now gaskets good but doing it again.like i said i can boost high for a while, pull over and no leaking, then run hard again thinking im all good and pull over and lose about a half cup of coolant.i guess pressure testing the cooling system is next.
Old 03-03-2008, 10:04 AM
david-b's Avatar
Dave is THAT guy
Drain and flush the system. Also, replace that damn radiator cap. If it's hissing, that's bad. Replace with stock OEM and see what happens there. Fix the small cheap thing first. I bet that's causing issues. Should be completely quiet from the cap.
75 Monte Carlo
