Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-28-2008, 09:50 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Battery dying in winter... update
Ok so as we all know as I've had the problem the past 4 years, when it gets cold, my battery dies over and over again. It jumps fine, runs great, but won't hold a charge when cold. Battery is new 3 times over and voltage gauge shows charging.
So last night I went out and jumped it as usual. She was under a sheet of ice so it took a while but I jumped her and for the first time EVER, the battery light turned on! The only time that light has ever turned on is when starting the car up, but never been on while actually running. Finally, somewhere! So the car ran fine. I drove 4 blocks to my parents house, shut it off, and couldn't start. Cranked but not enough power to start. That's normal.
After rejumping it again, ran fine, but with no battery light for the rest of the night. Actually started right up everytime afterward.
So, what does the battery light mean and how does it tie in with my problem? I'm glad it finally gave me something to look into.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-28-2008, 11:00 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: Battery dying in winter... update
Its technically called the "Charging System" light Dave
I still think it may be your alternator. Maybe the alternator getting cld has something to do with it?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 02-28-2008, 11:12 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
The light means that the voltage has dropped below 11v or something like that. Which would mean your alternator is bad or maybe the voltage regulator is bad. Whatever it is its only bad in cold weather.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-28-2008, 11:13 AM
david-b's Avatar
Dave is THAT guy
It was still showing 13.5 on the gauge though the whole time. Where's the voltage regulator at?
75 Monte Carlo
Old 02-28-2008, 11:30 AM
Holset powered 420a
I believe ours is built into the alternator
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-28-2008, 11:59 AM
wardak33 wardak33 is offline
yea, its your alternator. its finally giving you codes. go to autozone. not only can they pull the codes out for free, but also can check your battery levels and alternator output levels too (free as well)
2002 Oldsmobile Bravada AWD w/ SmartTrak
1999 Mitsubishi Galant 2.4L I4
