Go Back   Automotive Forums Car Chat > Cadillac > Fleetwood
Old 02-27-2008, 09:47 PM
lgoodlyw lgoodlyw is offline
Wink 1995 cadillac fleetwood
i have a 1995 cadillac fleetwood, the level control compressor comes on and off, can anyone tell me if they have had the same problem with there cadillac, ond hoe to correct the problem.
thank you.
Old 02-28-2008, 08:52 PM
yel yel is offline
Banned
Re: 1995 cadillac fleetwood
i used to have the same problem, when i had it checked, it turned out that i had to change my Cadillac Fleetwood heater core.
Old 02-29-2008, 06:36 PM
kads kads is offline
89 cadillac fleetwood the blinkers stop working after the car heats up( about 50 miles driving time) light comes on and don't blink untill it cools back down any ideas?? thanks
Old 03-01-2008, 06:36 AM
DFBonnett DFBonnett is offline
thank you.
Likely a leak in one of the lines from the compressor to the shocks or one of the shocks themselves. The easiest way to find it will likely be to get under and go over the components with soapy water and look for bubbles. If it is a line leak, I understand that the dealers sell a splice kit.
FWIW
YMMV
Old 03-01-2008, 06:39 AM
Sounds like a failing flasher. You might try replacing that first. Also check the relevant bulbs when the trouble occurs. You might have an intermittent bad filament in one.
Old 03-01-2008, 08:48 PM
thanks i will replace the flasher tomorrow thanks
