Old 02-27-2008, 08:35 PM
lilwalk lilwalk is offline
Angry 2004 pontiac grand prix GT2
my car dies out while driving and now it won't start back up. HELP! every time i start it, it sputters and dies out. i had the same problem a year ago. i took it to a GM dealeer and they changed the module. it has ran pretty good until now. its not the battery either. does anyone have any suggestions?
Old 02-27-2008, 09:54 PM
m2m2004 m2m2004 is offline
Re: 2004 pontiac grand prix GT2
Since it isnt the battery, and it dies when driving it dosent sound like the starter, it might be your ignition. Make sure your conections are clean and free from corrosion.
Old 02-27-2008, 09:57 PM
where do i look for these connections?
Old 02-27-2008, 11:03 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
does it immediatly start right back up? will it run good when restarted?
Maybe when it wont start, check fuel pressure and spark to see whats happening.
NOt sure what motor is in it, but if its the 3800, these have ha problems with faulty MAF sensors.
You could try running it with the MAF disconnected.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 02-27-2008, 11:11 PM
it has a 3800 in it. it will start up then die out or it just sputters and don't start.
Old 02-27-2008, 11:23 PM
tblake's Avatar
In God We Trust
Yes, go unhook the MAF sensor and run it, see what happens. If it starts and runs good, you found your problem.
Any check engine lights on?
Old 02-27-2008, 11:51 PM
the emission light was on but it went out
Old 02-28-2008, 12:04 AM
tblake's Avatar
In God We Trust
might want to have it scanned for DTC's. Even though the light isn't on, there could still be DTC's stored.
Go unplug the MAF yet?
Old 02-28-2008, 12:20 AM
i'm at work right now, but tomorrow morning i'll unplug it
Old 02-28-2008, 12:24 AM
tblake's Avatar
In God We Trust
wow, you work the late shift?
Its way past my bedtime.
Good luck!!!
Old 02-28-2008, 12:46 AM
Thanks!
Old 02-29-2008, 07:26 PM
Its the fuel pump. its not getting enough pressure
