Go Back   Automotive Forums Car Chat > Pontiac > Grand AM > Tips and Maintenance
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 02-27-2008, 08:28 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Thumbs up 1999-2005 Door lock/Window button Light-bulb change -- LED Conversion Procedure
These factory bulbs are available at the Dealership only.
Part numbers coming soon...
For the passenger side door lock-Window button, and driverside door lock light;
- Remove the button bezels see this thread.
Disassembly of your 99+ N-Body Interior
- Unplug the two plugs, they are held in with a clip that you depress. Should look like this..
Yello arrows are the tab release for the switches.
Red arrows are the cplug-clips.
Once you have unpluged them, it should look like this.
The center part(red arrows) is the bulb, unscrew to remove. SHould look like this for the pass side window and both lock buttons.
- Replace bulb in the reverse procedure.
-- For the Drivers side, see the previous Disassembly thread to remove the button bezel.
- This procedure is a little more difficult but can be done.
- Unplug the plugs for the lock and window button.
-- if you have a power mirror it should pop out .
- To remove the switch from the bezel you'll need to pry the tabs with the red & yello arrows and pull the switchs out of the bezel. Notice the 3 plugs, two on the window button, one for the lock.
The area in Red(plug ins) will stay attached to the circuit, cover lifts around.
- Thier are tabs holding it in on both ends, these need unclipped to remove the bottom switch cover.
-Then once the bottom cover is removed from the switch it will look like this.
- Blue circles indicate the tabs that need twisted to remove this board to access the window button bulb.
- This is with tabs twisted and ready to pop out.
It should lift out with a small screw driver, working it from both ends to keep it even as you pull it out.
This is what it looks like when that board is removed.
Center circle is where the factry bulb goes, it unscrews as the others. This is the factory bulb & holder.
- To replace bulb, reverse procedures.
1999 Grand Am SS 3.4 OHV
Old 03-01-2008, 12:58 AM
Re: 1999-2005 LED Conversion Door lock/Window button Light-bulb --
For the LED conversion you will need LEDs, resistors and the factory bulb holder(s), a soldering iron and some sodler, and heat shrink tubing, and Kneedle nose plyers.
If you aren't good at soldering, you probly wont want to try this.
Depending on what voltage your LEDs are deciedes what size resistors you will need. Here is a pic with the formula I used.
This chart shows the color band for resistors.
So your average car puts out aprox 13.8 volts, and if you have 1.5 volt Led's w/ %5 tolerance @ .02 milliamps here's what we get.
Vr=Vsup-VLed
13.8-1.5=12.3volts(Lckt)
12.3/.02 = 615 ohm
Ok we'll do some other variances with different LED voltages.
13.8v-2 = 11.8volts
11.8/.02 = 590 ohm
13.8v-2.5 = 11.3
11.3/.02 = 565 ohms
13.8v-3 = 10.8vlts
10.8/.02 = 540 ohms
Now they dont make every single one of those resistors, so you have to round down, or the nearest.
I used a assortment pack of LEDs ranging from 2-3v.
So I went for the middle of 2.5v which was the 565 ohm, rounded to the nearest resistor that was available was 560 ohm. Radio shack 5 or $1.
Ok using the previos post to remove the bulbs.
- Remove the factory bulb by lifting out the wires, then pull bulb out the top. Then using the plyers bend you LED wires(gently) like this.
LEDs are a one way circuit so the longest wire is the positive, you might mark this one red to help later when installing the bulb.
Bend ends over toward the middle then cut off the excess wire. Should look something like this.
You might have to file/grind off a little bit of the LED to get it into the fixtures. I dremel tooled my fixtures .
Here is a pic with the LED installed in a lock button.
For the drivers bulb is the same as aboe just a larger base.
Now for soldering the resistors.
Starting with the pass side door lock, its the gray wire. Cut it about 1.5" from the switch, allowing enough room to solder the other end, these wires are short/tight.
The window button has two gray wires going into one, they all need used.
You will want to put your heat shrink tubing on before soldering both ends.
For the drivers lock is the same as above, the window button is the gray wire, two different sets here, you want the "A" wire which is also two wires like the pass side.
Twist the two together and solder your connections(same with pass side.
Installing the pass side bulb ......
Here is the pass side window button with positive side marked with the red "+". You can verify this by the grey lead wire on the plug in.
Pass side lock ...
Installing the drivers window bulb.
Looking at the switch ciruit, you can see I hav marked the positive side, this is where the positive side of the LED needs to make contact with.
Here is another pic with out the LED
Once everything is back together they should look something like these....
If you have any questions, feel free to PM me or post your question(s).
Old 04-02-2008, 03:30 PM
Re: 1999-2005 Door lock/Window button Light-bulb change -- LED Conversion Procedure
Also here are two web sites for wire diagrams.
1999-2005
http://www.the12volt.com/installbay/...d/Pontiac.html
http://www.bulldogsecurity.com/wireing%20diagrams2.htm
Closed Thread
