Old 02-27-2008, 07:08 PM
dube5878 dube5878 is offline
Front side marker bulb relacement
Just wondering what I have to do to change the front turn signal light bulb that is on the side of the headlight. I was looking for a plug to just twist to expose the bulb but I couldn't see anything.
Old 02-28-2008, 02:21 PM
maxwedge maxwedge is offline
A990 racer
Re: Front side marker bulb relacement
Gotta get in behind the h'lamp assy, from under the hood.
Old 02-28-2008, 08:07 PM
83cutlass 83cutlass is offline
Yeah might have to remove the headlamp to access that bulb. To do so, you have to partially or fully remove the grille and then lift up on the tabs to release the headlamp assembly.
Old 04-01-2008, 08:09 PM
Well I changed the bulb, no need to pull out the grill and headlamp. Just twisted it with my fingers and used a small pair of pliers to pull it out. Disconnected the power line to the bulb, swapped them out, and was able to put it back in with no tools. It's easier to get in then take out. Thanks for all the reply's.
Old 04-01-2008, 08:14 PM
Ah yes the little 194 bulb for the side marker. I just did one yesterday. You're right you can get it out with out pulling the headlamp on a T/blazer. I don't believe thats true on the other S/T trucks (Bravada, Rainier, etc.)
