Old 02-27-2008, 05:12 PM
Davescort97 Davescort97 is offline
Escort guy
Spark plugs
What kind of spark plugs do you use and how have they worked?
Old 02-27-2008, 11:03 PM
tripletdaddy tripletdaddy is offline
Re: Spark plugs
I've used Autolite, Autolite Platinum and Platinum Pro on various vehicles, engines with no problems. NGK on an ISUZU no problem. Bosch on small engines no problem. Champion on small engines no problem.
BUT I will never, never use Champions on a car. They screwed up a cross reference on my car and they had to be changed when was having problems with the car. I should have used Motorcraft or Autolite since it was a Ford. I was young, foolish, and didn't know any better at the time.
Old 02-28-2008, 03:28 PM
Escort guy
Re: Spark plugs
I currently run Bosch plus 4 plugs on my 97. They have 4 ground electrodes and a platinum center electrode. They only fire one ground electrode at a time. Has anyone used these and what did you think of them? I am going to get some NGK Iridiums when my current plugs have ended their useful life. Sparkplugs.com ran dyno tests on 7 different types of plugs and the NGK Iridiums pulled the most HP.
Old 03-05-2008, 08:10 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Re: Spark plugs
I buy whatever is on sale at Wal-Mart. The only plug I've ever had trouble with is Champion. I won't use those even in a mower!
Old 03-18-2008, 03:32 PM
shermancelmare shermancelmare is offline
Re: Spark plugs
I'm running Motorcraft OEM. I have used Bosch +2 plugs in other cars...you don't have to worry about gabbing them, but considering all the negative coments regarding them I wouldn't buy them again.
Also, if you pay $2.50 for plugs instead of $5, you can replace them twice as often. I think that is better then getting a premium plug.
Old 03-18-2008, 04:40 PM
Arnoldtheskier Arnoldtheskier is offline
Re: Spark plugs
I looked the other day..lesee..Champions are $9.86 for 4. Irid's are $45.58 for 4. I am not a fan of any particular. spark plug. Never had a problem with any brand. It would be extremely hard for me to be convinced to spend 5 times as much. I put cheap plugs..can't remember..they may have been Champions??..in and they still ran as new after 40,000 on my 93. My 93 had whatever they came with new..I guess Motorcraft..for the first 10 years/130,000 of it's life before I bought it. How do I know they were in there that long? Because I was pretty much 100% sure that I would destroy the head getting them out!! IF the head didn't crack it was surely helicoil time..Probablly would of if I had not soaked them in penetrating oil AND used an impact gun. Even then I had to back them out a bit,re-spray and then re-tighten them a bit..back and forth to get them out. They came out with no damage. BARELY.When out they actually looked pretty good INSIDE! I could not believe how rusted the outside was!!. But the insuators were still ok..white..Real nice color inside too! The electrodes weren't worn that bad. They did have about .100 gap. Car ran like new..only reason I did the plugs was that I was doing a belt/pump.
Old 03-18-2008, 05:15 PM
Re: Spark plugs
I thought Ford put a little bit of paint on their factory installed plugs so that the dealership and other people, mechanics would know if they were original or not. Did yours have any paint or marking on them?
Old 03-18-2008, 09:03 PM
Re: Spark plugs
Hi.. To be honest I never looked/noticed anything unusal/different about them.
I bought this car used 10 years old with 130,000 miles on it privately. "Well maintained". It had only ever been registerred to a dealer. Hunh? This I found out AFTER I bought it. I never even looked at that before I bought it. It looked like new/ran like new. SOoooo I did not check it out real thorough. Oil/filter,minor maintenance..lol..for 9 months..till I realized it had been hit/shoddily repaired and the rear strut pots collapsed. That I fixed myself. Big job.
It was AFTER that that I went over and maintained this car with a VERY FINE TOOTH comb. This car was a testament to the Ford Escort. How so many original parts went so long with so little maintenance I dunno. Every part I went to inspect,check,replace was pretty much an original one. Never the less. Best car I ever owned/will ever own. I got another 5 years/100,000 out of it.
I used to work as an automotive machinist so I saw plenty of poorly maintained engines when we had to strip/machine/re-build them. I got to know when stuff was gonna break before I took it apart. We used to tank some rare,old heads with the plugs in them if they didn't come out easy just to give us every advantage in salvaging them. Some cracked anyway no matter what we did. I still can't believe that those Escort plugs came out without destroying the head..or at least having to helicoil them. They came out easy the next 2 times.
A lot of people think aluminum lasts forever. It rots/corrodes and adding threaded steel fasteners to it/in often sets up some different and nasty problems depending on the fasteners.
While many manufacturers reccommend really long plug life intervals to sell their product or low maintenance..plus the difficulty of plug replacement..a LOT! of pro's in the field now say...sure the plugs can/might last that long and the car runs fine now what about WHEN you do have to change them at a bazillion miles.
imho 40,000/2 years is long enough for any plug. This 60,000 mile 5 year plug thing can be real grim getting them out/getting new ones in.
