Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 02-27-2008, 04:04 PM
Alphamalez32 Alphamalez32 is offline
Exclamation Heeeeeelp
I tried to see if i was able to do a convertion to a VH engine but found it to be too expensive. I decided to try to fix my engine. As I was driving the car, I notice that everytime i came to a dead stop and tried to press on the gas to the floor the car hesitated and almost shut off. I continued to drive like this for a few days until a week ago as i was driving not even at 30 miles/hour the car kinda choke and shut off. the car will crank and turn on for atleast 5-10 seconds but then die. I was told that this could be that the car was flooded with gas but i pinch the hose and the same thing continues to happen. I wanted to know if any of you guys have any idea of what could be causing this problem. Any input are welcome, thank you for your time.
Old 02-27-2008, 08:56 PM
Hodo Hodo is offline
Re: Heeeeeelp
Dirty throttlebodies. Easy fix.... can of carb cleaner and a toothbrush you are not using. A 10mm wrench will come in handy too.
Disconnect your battery. Take your intake pipes off, open your throttlebodies with your hand and sprey with carb cleaner, take the toothbrush and brush your throttlebodies clean. They should look like a brushed steel pot on the inside so clean them.
Finaly got pics of my car....... after I washed it of course.
Old 02-27-2008, 09:26 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: Heeeeeelp
Also, check for ECU codes. Here is a write-up on how to do it by yours truly.
http://forums.nicoclub.com/zerothread/249406
ZedEx Crew Member #2
Old 02-27-2008, 09:46 PM
Re: Heeeeeelp
Check the codes BEFORE YOU DISCONNECT THE BATTERY.
Old 03-07-2008, 01:30 AM
Re: Heeeeeelp
after cleaning the throtle, the problem persisted so i decided to take all the front covers from the engine. I found out that all my cams were out of timing. I don't know how but the lower pulley broke and the timing belt got loose but lucky enought that it didn't broke. The cams were each out of time by atleast 3 teeths. I don't know how but i was so lucky that none of my valves or anything else in the engine didn't bent nor broke. After i replaced the timing belt and lower idler the car just started like a champ. thanks for the replies guys.
