Old 02-27-2008, 03:12 PM
juicydog42 juicydog42 is offline
My Heater does not work on my 200 Oldsmoblie Alero
I have a 2000 Olds Alero four door, V6. About a month ago my heater went out on the first two notches, when I turned it up to the third and fourth notches it worked. The other day all of them went out and I have no heat. I have chagned all the fuses that pertain to the HVAC but the only thing that works now is the fan. I was driving to work the other day and could feel a little bit of heat trickling out when I was pushing on the gas but it does not blow out. Any suggestions. Thanks!!
Old 02-27-2008, 03:21 PM
inafogg inafogg is offline
Re: My Heater does not work on my 200 Oldsmoblie Alero
hello sounds like a resistor problem atleast when you lost #1 #2 speeds its located down under dash where fan motor is located.parts are $30 1/2 hr to replace GOOD LUCK
