won't go in reverse
I have a 2001 automatic, won't go in reverse. Replaced brake light switch. Is there anymore switches or senors I need to check?
Re: won't go in reverse
does the shifter go into reverse but the car does not?
ASE Master certified and VW certified. Just here to help all check engine light codes ------> http://www.automotiveforums.com/vbul...d.php?t=328630 |
yes, you can put the shifter on reverse, & it's just like you put it in neutral. there's no difference between reverse & neutral. the engine doesn't change speeds or anything.
sounds like the fluid level is low in the transmission. I would have it checked by a vw shop or dealer.
