Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 02-25-2008, 10:11 PM
kosmoquez kosmoquez is offline
88 GT help
My GT is making a winding/whining noise from the pulley area. Most likely the bottom middle. Noise is faint when in idle and will increase with increase in RPM. Does anyone have an idea of what the problem could be?
Old 02-26-2008, 01:07 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: 88 GT help
waterpump
1969 Cougar
357w & TKO - 475hp
Old 05-25-2008, 01:46 PM
Tuffdrvr88 Tuffdrvr88 is offline
Send a message via Yahoo to Tuffdrvr88
Re: 88 GT help
He is probably right. The bottom of your waterpump should have a small hole at the bottom called a "weep" hole. If the pump starts to go you will usually see coolant dripping from it and may even notice it on the floor. Take the belt off and spin the pulleys by hand. They should give you much resistance at all. Check under the car and look for white chalky stains which could be coolant that dried before hitting the ground. Hope that helps, take care.
