Old 02-25-2008, 08:20 PM
rickisrad rickisrad is offline
Rack- pressure valve,fluid questions
I am replacing the rack on my 98 Windstar 3.8, my questions are- Do I need to put the retainer washer in with the pressure valve? I took my old one off and it did not have one, so I was not sure that it is that important as long as I have the valve in there?
- Would Valvoline Syn power power steering fluid be sufficient or should I use a synthetic transmission fluid. Also If I use a transmission fluid can I use lucas transmissio additive to help with friction?
Thanks for your help
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 02-26-2008, 06:07 AM
wiswind wiswind is offline
Re: Rack- pressure valve,fluid questions
I can answer the fluid part of your question, you need a ATF that meets the Mercon or Mercon V specification.
You should not need to add any additive, and I would recommend against it.
You still need to keep the fluid fresh, and you will be fine.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 02-26-2008, 06:11 AM
12Ounce 12Ounce is offline
I recently replaced the rack on my '99. I had the subframe dropped for other work and it seemed like a good idea at the time. Figured it would tightened up the steering/play. I don't remember any retainer washer ... but there may be a model difference.
I have been using only the Valvoline for many miles/years on several cars. Seems to work great.
Old 02-26-2008, 06:35 PM
I went ahead and got some Mercon V for the power steering/rack.
Anyone else know if it is safe to install the pressure valve without the retainer????
Thanks for the replies
Old 04-15-2008, 11:53 AM
garynel garynel is offline
Hi, new to this forum but have found lots of good info browing through. I have replaced the steering rack on my '98 3.8 windstar-the question I have is when I set the old rack down on the garage floor, a small metal 'button' dropped out from one of the hose ports. it is open on one end and has a very small opening at the other end. Is this the pressure valve referred to here? I am guessing it goes in the pressure hose port, but which end points in? I haven't been able to find any diagrams that show this part. Thanks for any info...
