fuel injectors... can I do them???
I have swung a wrench here and there, but very much a beginner.
My engine started shaking really bad, I took it to pep boys because just 3 months ago they replaced the valve gaskets and head gaskets ($3000) so I thought maybe it was something they did...they tell me its one of my injectors is out, Pep boys tried new wires and a coil to no avail. So the guy said he was pretty sure it was the injector.. He thought it might be the rocker, but if the rocker was bad the compression would be bad, and they tested the compression and it was ok. So, I looked at the gasket tutorial pinned to the top, and getting to the injectors didnt seem that bad, I don’t have a torch wrench, but I'm sure its less the $500 pep boys is going to charge me. So has anyone done there injectors??? Is it really difficult? Thanks for your help guys, this car has 127k miles and Im sure it would love to die, but I can't afford a new one, so I have to make it work... |
Re: fuel injectors... can I do them???
Welcome to AF, a broken or pulled rocker stud does not show up as bad compression, check that first.
Remove the valve cover on the suspect cylinder side and look at the valve train.
[quote=chasecrusher]I have swung a wrench here and there, but very much a beginner.
quote] Me thinks you better find a repair shop to repair or at least diagnose this problem as you do not have a good understanding of this type of work...most likely the head gasket repair has something to do with your problem and for 3000.oo i would get another shop to diagnose then ask if the work pep boys did had anything to do with it and if so get the statement in writing then get pepboys to correct it..... |
[quote=j cAT]
[quote=j cAT]
They don't know for sure that pepboys messed it up, the car has 127000 miles, they say it "looks" like pepboys may have messed it up, its a month past and a thousand miles over pepboys warranty, I really have no rights to demand anything. The car ran fine until the other day, so I also can't say pepboys didn’t fix it. Thanks for the "law" lesson, but I don’t think it really fits my particular situation. Also I have contacted the main office, and it really has got me no where... so what do you all think, can an engine swap be that cheap? |
