| Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
'67 Fastback Overheating
I have a 1967 Ford mustang fastback. Right now it has a 351 Cle engine, 4 barrel holley carb, aluminum intakes, flowmaster dual exhaust system, new radiator.
Now whenever the mustang is not in motion, it has a tendancy to overheat. I put in a new radiator with new hoses in the other day and made sure my water pump and fans still operator. But it still overheats. Am I dumping too much fuel into the combustion chamber or does the aluminum intakes have a part in this? Please help me out here. |
Re: '67 Fastback Overheating
Make sure you have enough water in the system, no air pockets.
Make sure your water pump is turning the right way. Make sure your thermostat isn't stuck open. Make sure your fan is turning the right way. - Also what fan do you have on the car? Flex-fans are prone to overheating. I have the stock 2 core brass radiator and mechanical (non-clutch) fan without a shroud in my '69 Cougar. It's got a 475hp 351w and runs just over 155* with a 160* t-stat in it. I'm actually installing a 180* t-stat to try to get it to heat up a little. You may want to check your timing. If its not advanced enough then its will cause your motor to overheat.
1969 Cougar 357w & TKO - 475hp |
I have a dual fan system that sits behind the radiator and a single in front of it. I dont know exactly what type of fans they are because they are about 10 years old. I know they are made of polyurithane or some other material. They are installed correctly and that is one of the things I looked at. The water pump was placed in correctly with the help of my father (original owner and grease monkey) And I just purchased a new thermostat but have yet to put it in. I was thinking that the upgrade from a 289 stock engine to the 351 with the 4 barrel holley carb would be producing too much power and heat. Maybe that the radiator is not up to par with the amount of power i am using? I have a replacement radiator but it was the size for a 289. Can that be the problem?
I have a toggle switch to turn on all fan circuits. I have not drive my mustang since california. Currently i am residence to Washington state, much colder environment. But i do not wish to drive if it is going to harm the engine. But will a small radiator that is not up to par with a bigger installed engine do it?
It could. Most of the 289/302 radiators were single core. 351w/c radiators were 2 core & most FE stuff was 3 core.
Sounds to me like a fan/rad upgrade is needed. Spend the money once and get a 16" Spal fan, you wont regret it, its the only one you will ever need.
Thanks you guys for your help. I'll see what I can do.
No problem. Got any pics of the car? I love the old ones.
I'll get my digital camera tomorrow from my ex-fiancee and grab a few shots for you guys. Rebuilt 351 cleveland with only 1,800 miles on it. new jet black interior, origial/referbished dash and gauges. Hurst shifter 4 speed manual. The only thing left to do after this overheating problem is the paint job. Fiberglass "dragon snout" hood with functional scoop. ^_^
