Old 02-25-2008, 04:47 PM
Zwoof Zwoof is offline
volt meter issue
my voltmeter (in dash) will be holding steady at 14 then drop to 12ish then it will go back to 14, I drove most of the way home today and it was sitting on the low end...I tested the battery with the engine off and it was 12ish (my meter scale is small and hard to read exactly) With the engine started its reading 14 (even though the in dash volt meter is reading low)
I started it again and this time it was reading 14 again..The batery terminals are clean and tight and the car runs well....Any Ideas? Thanks in advance of any replies
Old 02-25-2008, 05:25 PM
j cAT j cAT is offline
Re: volt meter issue
I would look at the back of alternator and make sure all connections there are clean and secure and measure at this point with meter for voltage of 14.25 with engine running.....if your alternator has a connector with small wire remove and inspect as these tend to get corroded...
Old 02-25-2008, 11:17 PM
drdd's Avatar
drdd drdd is offline
12V with a voltage tester is too low. It should be 14V without the truck running
if your dash voltmeter flickers or jumps down and then up, it could be your belt tensioner needs replaced --- easy to do and cheap!
Old 02-28-2008, 11:26 PM
Spectria, L1 MT's Avatar
Spectria, L1 MT Spectria, L1 MT is offline
Send a message via AIM to Spectria, L1 MT
In a perfect world, the voltage at the battery should be 12.7 at rest, engine off. If it has 14 volts, that would be very strange as the battery is rated at 12 volts, actually 12.7, or about 1.265volts per cell.
State of Charge Voltage12V
100%1.265
75%1.225
50%1.190
25%1.155
Discharged1.120
Good luck reading the chart I posted, this forum doesn't format cut and paste.
Charging voltage should be 13.6 to 14.2 volts.
I am not sure with the electronic dash, but poor grounds for the cluster used to cause flickering gauges and incorrect readings with many vehicles, including my 94 jimmy with electronic dash.
Also alternator brushes worn to the end of their life (at the end of the spring) often cause varying outputs.
