Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-25-2008, 03:17 PM
EclipseG13 EclipseG13 is offline
Clatter From The Hood - Tales Of A Serpent!
Hey everyone... quick question here.
My car has been clattering lately... I popped the hood to see where it was coming from and it looks like the serpentine belt is bumping up against the plastic cover to the left of the motor.
Now my question is, is it something that could be easily fixed.... I do not have extensive repair knowledge but with some pointers I can do a lot. Im getting quoted about $120 + to have a new belt put on (im guessing that if its a problem with tension it will be fixed with the installation of the belt fixing the clatter) so it would be cool if all I needed to do was pop that plastic piece off and tighten down a bolt.
Thanks!
PS - its a 95 eclipse RS / No Turbo / 2.0
Old 02-26-2008, 11:54 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: Clatter From The Hood - Tales Of A Serpent!
What plastic cover for the Serp?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 02-26-2008, 12:04 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
I'm thinking he's talking the timing belt cover? That's the only plastic piece on that side of the motor. If the serpentine belt (any of them) are hitting the cover, it would be very very very off balance and the belt wouldn't stay on. I would say this needs to be clarified a little more before we can help.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-26-2008, 12:07 PM
JoeShmoe's Avatar
Old 02-26-2008, 01:50 PM
Then I would say its the timing belt. My mistake, it must be the timing belt.
Which is not good im guessing....
I looked around online and I read that 95 eclipse's are prone to bent valves when the belt does give.
Can anyone shed some light?
Thanks!
Old 02-26-2008, 02:06 PM
david-b's Avatar
Dave is THAT guy
Thanks!
Let the light shedding begin...
All motors are prone to bent valves when the timing belt or timing chain breaks. The valves go and bounce off the piston, causing the valves to bend and piston head crack is also possible. So if the timing belt is rubbing against something, that needs to stop.
So you're saying that the timing belt sounds like it's hitting off the timing belt cover then right?
Where exactly is the noise coming from? Like middle, lower, upper?
If so, you can take off the outer timing belt cover pretty easily with some basic tool and see if it's bent or whatever.
75 Monte Carlo
Old 02-26-2008, 02:23 PM
Thats what ill have to do.... I cant really tell where its comming from, it just kind of rattles.
I also read it could be a stuck tensioner thats causing it but im guessing thats not cheap to fix either.... After I found that it could be the timing belt I called around for quotes and the best I could do was $306 without parts, and thats if everything else is all good on the checklist.
Old 02-26-2008, 02:29 PM
david-b's Avatar
Dave is THAT guy
Thats what ill have to do.... I cant really tell where its coming from, it just kind of rattles.
Ya timing belts aren't cheap. I don't think you need one unless the car has 60-80k miles on it and it's never been done.
I don't believe the stuck tensioner neither. You'd be having more problems with it then. Not just a noise.
75 Monte Carlo
Old 02-26-2008, 02:30 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
This is only true on interference motors.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-26-2008, 02:37 PM
david-b's Avatar
Dave is THAT guy
Well I wasn't going to go into details on stuff that doesn't pertain to this situation, or anybodies here. Let's keep it to the E/T/L now haha. Just kidding
75 Monte Carlo
Old 02-26-2008, 02:56 PM
Holset powered 420a
The 1.8 motor isn't an interference motor. So it does pertain to this section. How about that
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-27-2008, 01:03 PM
JoeShmoe's Avatar
Chill out man, no need to argue.
Old 02-27-2008, 03:50 PM
BTW....
I dont know if this is relevant but the sound is not there when the motor is cold.... sometimes when I start it up after its been sitting over night you cant hear it for about 5 mins and then once the car is at idle you can hear the rattle.
Old 02-27-2008, 05:08 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
But this guys car isn't a 1.8 so it doesn't pertain to this thread.
I would say take the belt cover off and take a look. If need be just leave the cover off, and make sure you don't drive over anything that might get thrown up into the motor.
1991 GSX 2.3 Stroker
Old 02-27-2008, 06:10 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
You're not hearing some sort of lifter tick are you, you're SURE it's coming from the timing belt area?
95 Talon TSI AWD
97 Eclipse GST
