93 Century 3.3L Transmission Mount Replacment Questions
Hey I have a bad Transmission mount. Its location is on the front driver side of the transmission.
I took a look while i was changing the oil... I would like to change the mount (so the tranny will stop moving when I shift gears etc.).
Can the mount be changed without removing the engine/tranny? The mount has like a metal hook that locks into a bracketor the frame... I am guessing its to keep the tranny from moving too much if the mount breaks..
I have no idea if I would be able to get the new mount to hook into the bracket as its pretty tight under there... also the 2 monting bolts that go through the frame look pretty rusted. I am pretty sure the studs will shear off if I try to take it apart... This only worries me as I do not know if the mount can be serviced without removing the engine/tranny.
Any help would be greatly appreciated.
Kevin
