Old 02-25-2008, 10:57 AM
Ridgeway Ridgeway is offline
Random Ticking Noise.
Hi all. I have used the search function and still couldn't find anything like my problem so here goes.I just got my Jimmy home from the shop TODAY after having the tranny replaced. I knew it was baked and I knew the cost going in and that's not my problem. I have this random ticking/clicking(still).By random I mean it does not stay in tune with the motor.It sounds like it is coming from the midway point of the vehicle. It makes this noise at startup and when you take off(sometimes) The mechanic does not know what this is and said that he in fact had checked the flywheel for cracks/damage and there was none while replacing the tranny. Several people have run along side of me as I took off and noone seems to know what it is.Sounds almost like a BB or nut or something rolling around somewhere. Many suggestions from protective shrouds to catalytic converter to something with my 4x4. If anyone has any suggestions please respond.
4.3 replaced in 2006.106K Kms on rebuild.
All balljoints/right side wheel bearing/pitman arm replaced during tranny work.The motor runs flawless.I like this truck(obviously) but she is starting to hurt the wallet.
Regards.
Old 02-25-2008, 12:28 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: Random Ticking Noise.
Was the ticking noise there before the trans was replaced?
Old 02-25-2008, 01:58 PM
Yes it was.Obviously I was hoping that it was the bad tranny.The new tranny is working great but that annoying clicking persists,
Regards.
Old 04-23-2009, 02:04 PM
nate6474 nate6474 is offline
My 2000 blazer is makeing the same sound and i got the transmission rebuilt and it is still doing it and the trans guy said it was the motor mounts and the pip is hitting the frame but he is wrong because it does it in nutral sometimes it makes the noise and somtimes it does not radom. I thank it is in the oil pan at the bottom of the motor maybe oil pump or a plate that they sometime put in the oil pan
Originally Posted by ridgeway View Post
hi all. I have used the search function and still couldn't find anything like my problem so here goes.i just got my jimmy home from the shop today after having the tranny replaced. I knew it was baked and i knew the cost going in and that's not my problem. I have this random ticking/clicking(still).by random i mean it does not stay in tune with the motor.it sounds like it is coming from the midway point of the vehicle. It makes this noise at startup and when you take off(sometimes) the mechanic does not know what this is and said that he in fact had checked the flywheel for cracks/damage and there was none while replacing the tranny. Several people have run along side of me as i took off and noone seems to know what it is.sounds almost like a bb or nut or something rolling around somewhere. Many suggestions from protective shrouds to catalytic converter to something with my 4x4. If anyone has any suggestions please respond.
4.3 replaced in 2006.106k kms on rebuild.
All balljoints/right side wheel bearing/pitman arm replaced during tranny work.the motor runs flawless.i like this truck(obviously) but she is starting to hurt the wallet.
Regards.
my 2000 blazer is makeing the same sound and i got the transmission rebuilt and it is still doing it and the trans guy said it was the motor mounts and the pip is hitting the frame but he is wrong because it does it in nutral sometimes it makes the noise and somtimes it does not radom. I thank it is in the oil pan at the bottom of the motor maybe oil pump or a plate that they sometime put in the oil pan I GOT FIDELIS AND THEY PAYED FOR THE TRANSMISSION
Old 04-24-2009, 09:06 AM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
I know you said that you replaced the right wheel bearing during the Tranny rebuild. But I assume that means the left one was good.
Does this noise happen at idle?
Does it go away at certain speeds?
Does it come back at higher speeds?
Does the sound go away during a right turn? A left turn?
If you run it on a freeway and go through a high speed right curve or a high speed left curve do you notice any difference?
I fought a similar noise for months and finally found the culprit on a freeway curve, the noise stopped. I replaced both front wheel bearings and the problem was solved.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 04-24-2009, 09:51 AM
toddman67 toddman67 is offline
Check the U-joints. If one is dry the needles will click and resonate through the drive shaft. A quick inspection of the joints would include a cap with rust showing around it. Otherwise pull the shaft down and look for a stiff or loose condition. Usually you will here a chirp or squeel if bad. Also a drive line vibration at certain speeds would be an indcator.
Old 04-26-2009, 06:57 AM
blazee's Avatar
blazee blazee is offline
Problem?
Please start a new thread with your problem, and we'll help you as much as we can. Continuing in this thread will simply cause confusion between you and the original thread starter. Can you describe with a little more detail what you are experiencing, such as what area the sound seems to be coming from, type of sound it is, etc. There are lots of things that can make a general ticking sound, such metal parts striking each other, an exhaust leak, or loose fasteners to name a few.
Old 04-28-2009, 06:14 PM
Regards.
i found the noise and it is the starter!!!!!! you will need a new one and you can get it on ebay. what it is. is that the teath of the starter is coming out a little and tuching the fly wheel and it makes a sound like balls or nuts going around in there, ramdom sounds like you said i have the samething i got the trans rebuilt and it was still doing it but i found it!!! it was the starter all along!!!!!! easy fix!!!
Old 05-04-2009, 06:28 PM
sinned700 sinned700 is offline
i had this same problem in my 03 bravada it sounds like the middle of the engien to fix it the dealership had to reprogram the fan cluch which i ended up replacing any way do it yourself its like $150 take it to a garage qote was $750
Old 05-04-2009, 06:33 PM
also just wanted to add that the ticking noise would happen when the car was at a stop sighn or light weather it was in park nutral drive or reverse and did not change with engine speed
