Old 02-25-2008, 08:57 AM
mistermoonpie mistermoonpie is offline
Octane Booster
The five dollar bottle found at gas stations and Wal-Mart. Does it work, and if so how well? My friend says he puts some in his truck when he tows something, and he swears he notices an increase in performance, slight though it may be.
'97 3000GT SL
-Short Ram Intake
-Test Pipe
-Custom Exhaust
-17" Infinity Rims
-Infinity Kappa Component Sound System
-Kenwood Double Din Headunit
Old 02-25-2008, 10:13 AM
G.A.S. G.A.S. is offline
Re: Octane Booster
I dont put much stock in octain booster. Bye regular higher octain fuel and then your running it all the time.
Run the proper ammount of seafoam ( http://www.seafoamsales.com/motorTuneUpTechGas.htm )through your fuel tank, that will increase performance. Cleans everything out real well.
Old 02-25-2008, 10:44 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: Octane Booster
First, more octane = less power if everything else is equal. However your car requires premium, so don't go and start using 87 octane
Second, lots of those things raise your octane something like 6-10 points. Well it takes 10 points to move up one octane rating at the pump. So if you were to buy 87 octane and put in the additive you would then be at 87.6-88
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 02-25-2008, 01:21 PM
AutostradaVR4 AutostradaVR4 is offline
Re: Octane Booster
i thought DOHC NA just needs mid grade?
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 02-25-2008, 01:22 PM
Crackhedbob341's Avatar
Crackhedbob341 Crackhedbob341 is offline
Re: Octane Booster
I use some in my N/A every once in a while. It isn't my imagination, but my car does seem a little peppier.
Never bring show to a go fight.
And a TT conversion brewing..
Old 02-25-2008, 01:30 PM
Re: Octane Booster
SOHC can run on 87, DOHC says right on the gauge cluster "premium unleaded fuel only". That means 93 or 94.
No, it is your imagination, unless you aren't putting in premium gas to begin with, then you may see a small difference. However, it is not as much of a difference as if you were to just put premium fuel in the tank in the first place.
Old 02-25-2008, 05:36 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Octane Booster
Octane booster will not even drive you up one point. It's a waste of money. Just put the fuel that is recommended by the manufacture in your car.
