Old 02-25-2008, 12:27 AM
shimaze shimaze is offline
Send a message via AIM to shimaze
I really need a timing belt cover and a crank & camshaft sprockets
Hey guys, I really need a timing belt cover and a crank & camshaft sprockets for a '96 1.0. The @$$ clown that put a timing belt on it before I bought it did not put all the bolts back in and one fell out & chewed the lower crank shaft sprocket that the belt goes on. I am in the middle of replacing the crankshaft seal and I want to put undamaged parts back on. If you have some parts from a bad engine you could sell to me, I would very much appreciate it. In case someone doesn't know, some older 1.0's have a narrow belt and the newer ones have a wider belt. The sprockets & the timing belt cover are different. An easy way to tell is the ones with the narrow belt have a stamped steel sprocket on the camshaft and the ones with the wide belt have a cast or forged steel sprocket on the camshaft. I need the parts for the wide timing belt. I thank you in advance for reply & help!!!
Old 03-14-2008, 10:07 AM
twyztedsteele twyztedsteele is offline
Re: I really need a timing belt cover and a crank & camshaft sprockets
I have a timing cover for a 1.3L with a wide belt, if you think that would work.
Old 03-14-2008, 10:08 AM
I have a timing belt cover for a 1.3L with the wide belt, if you think it would work.
