Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 02-24-2008, 08:00 PM
cluelessthenandnow cluelessthenandnow is offline
CD Player
I have 2002 xlt with the 5 cd player, 3 of which are stuck in there and it won't work. Ford wants $800 to fix!!!! I could buy 3 new ones for that!!
Anyone have any ideas how to fix? (and remember I am totally clueless about cars or these things!)
Thank you!!
Old 02-25-2008, 06:34 PM
Davescort97 Davescort97 is offline
Escort guy
Re: CD Player
Hello Clueless: I'im assuming you want the CD player to eject the discs. To do this turn the power on at the CD player. Make sure the CD player is turned on. Then....disrupt the power supply either by pulling the CD fuse or by disconnecting the battery terminal. Then put the fuse back or replace the battery terminal. Doing this should eject one of the discs. You might have to do this procedure three times, once for each disc. Make sure the key is in the accessory or run mode and the CD player is getting current before you do this.
Old 02-27-2008, 10:25 AM
Re: CD Player
Thanks Dave!! Now where do I find this CD fuse? Will this fix the player itself or just remove the cds? thank you!!
Old 02-27-2008, 03:40 PM
Escort guy
Re: CD Player
You'll find the fuse in the left hand part of the dash underneath. There will be a little box with a cover on it showing which fuse controls what. This may eject the CDs but don't think it will fix the player.
Old 03-06-2008, 03:46 PM
Unhappy Re: CD Player
rut-roh. Thanks for that. Any ideas on how to fix cd player???
Old 03-08-2008, 08:31 PM
highlandlake highlandlake is offline
Re: CD Player
Fixing them may cost more than it's worth. There seems to be an abundance of newer car radios on E-Bay - with extremely low prices on some. I had a cassette player in my Rodeo that went bad, so I bought a practically new identical one on E-Bay for $22 including shipping. It worked great for as long as I owned the vehicle.
My point is that for $22 I couldn't ever get a repairman who understands those things to even clear off his bench for that $. And then to actually fix it? $$$$$.
Makes more sense to buy a used one (or two or three if needed) and be ahead of the game.
Here's one for sale now for 20 bucks plus shipping....http://cgi.ebay.com/ebaymotors/Used-...spagenameZWDVW
Good luck, Tom
'65 Chevy Malibu SS
'06 Pontiac Vibe (a dead deer fits nicely in the back)
'04 Ford Escape
GMC S-15 4WD
'57 Chevy 210 post sedan
'51 Ford F2 pickup
Recently gone but not forgotten - 68 Chevelle, '97 Rodeo V6 4WD.
Old 03-09-2008, 10:46 AM
Re: CD Player
Good luck, Tom
Excellent idea!! Thank you for the tip! I assume these are pretty easy to install? Remember I am totally clueless!
Old 03-09-2008, 03:05 PM
Re: CD Player
Good luck, Tom
Thank you Tom, I am going to bid on that one. Are the escape OEM compatible with explorer of same year. The one you noted above is a 2004 escape. Mine is 2002. So the year doesn't matter correct? It is so hard to find any info. I went to Ford site and they only have info for 2004 and later.
Thanks!!
Old 03-09-2008, 06:25 PM
Re: CD Player
Clue, no problem - glad to help some.
As for install tips on these.....I've never done it on my Ford. But if it's anything like other cars you simply have to carefully pop off the bezel around the radio. (I'd look outside at mine but it's dark & cold outside here in Maine) These usually just snap in place with no screws on newer cars. The bezel might be quite big and have a couple of dash control wiring connectors to separate, but it shouldn't be difficult or require highly special tools. With the bezel off you should be able to see how the radio is fastened in there. Maybe an 8 mm headed screw or two. Possibly a bracket holding it in. Anyway, get that radio loose and carefully disconnect the wiring connectors and the antenna cable (plugs right in?) You should have the radio CD player in your hand. To replace it, just reverse the order of removal steps.
Your next question about whether a 2004 will fit a 2002. What does the picture looks like compared to yours? If they aren't identical then remove yours first and get the model number off the side/back of it. Then send the E-Bay seller a question about what his model number is. Maybe ask for a couple pictures of the back connectors and some dimensions, etc.
If no match, then watch E-Bay for a week, one might show up. This car is common, the CD player should be too. Also try the 'Want It Now' feature on E-Bay by being descriptive of exactly what you want with models numbers, etc.. You might get a response in a couple of days.
Let us know how it goes.
Tom
'65 Chevy Malibu SS
'04 Ford Escape
GMC S-15 4WD
'51 Ford F2 pickup
Old 03-15-2008, 10:59 AM
Talking Re: CD Player
Tom
Thank you Tom. I wasn't able to get mine out this week so I lost out on the 2004. There are 2 on ebay now for 99-2003 fords. The pictures are the same from the same seller but it doesn't show the 2 holes on each side. I emailed him and he said it does have but the pictures clearly don't reflect that and has some metal attachment on bottom which as you know I am clueless about. Any thoughts?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=300205569311
Thanks so much!! It ain't easy being clueless!
Old 03-16-2008, 01:49 PM
Re: CD Player
Wow - that CD player sold for more than I would have imagined.
But it does look just like the one in my '04.
The seller may be right about it being common to many models. If so, use that to your advantage and confirm what yours looks like in the back. Then do E-Bay searches for specific Ford models and you may stumble across one at a real good price. What about the Mazda Tribute? It's the same as our Fords. Might have the same radio? The good news is that the radio in that auction you sent seems to be quite simple to unplug and plug in - nothing special. Just a bracket holding it in place. Hopefully you won't have to be a contortionist to reach behind it to get the fasteners loose. Good luck. Tom
'65 Chevy Malibu SS
'04 Ford Escape
GMC S-15 4WD
'51 Ford F2 pickup
Old 03-16-2008, 02:05 PM
Re: CD Player
Thanks Tom. They are all selling for that much! I ordered one of those ford thingys, so when I receive, I'll remove player so I can confirm. I asked one seller and he said his would fit if i had two wires not 3. AS IF, I'd even have a clue! But I'll also try the tribute as you suggest. Thank you!
Old 04-27-2008, 12:00 AM
danielsatur danielsatur is offline
Re: CD Player
Disk's are old school,put them with your 8-track tapes,Albums,and
cassettes.
GO to Best-buy and buy a GPS,so you don't get lost next time.
Also pick up a IPOD to carry your playlist.
These gadgets are cheaper + better than that old cd player.
You can also, use these gadgets for your other cars too!
MCGIVER
