Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 02-24-2008, 06:10 PM
piimahoe piimahoe is offline
Red face ignition key locked and won't come out?
ignition key locked and won't come out? It's stuck in the acc position. it will start and turn off the motor but will not turn complelely to the off position so i can pull out the key.
Old 02-25-2008, 12:49 AM
leepotter leepotter is offline
Re: ignition key locked and won't come out?
If there is still a warranty(3yr 36kmi) take it stright to the dealer. If not try your local locksmith.
Old 02-25-2008, 09:54 PM
mikedudley17's Avatar
mikedudley17 mikedudley17 is offline
Send a message via Yahoo to mikedudley17
wow, u sure ur not leaving the automatic in gear??? thats odd if not, take a trip to the dealership.
damn aveos!!!
Old 05-21-2008, 04:49 AM
orangekitty orangekitty is offline
If this is an auto it's likely the shift lock is responsible. I had to take mine in for warranty service and they found the mounting tab was cracked, wihich prevented the sensor from knowing it was in park. You can try jiggling the shifter around in park, pushing it left, right, up, that might free it up to at least remove the key. Problem will not go away so you must get it fixed.
Old 12-20-2009, 05:45 AM
teasider teasider is offline
I have the EXACT same problem!
I bought the car 5 days ago , with only 22000km.
2 days ago , I arrived to my destination, and all of a sudden the key wont switch to LOCK. and its just stuck there.
If I want to switch it to lock I'll have to jiggle and play with it for like 3-4 minutes. (totaly destroys my hand.).
I took it to a chevrolet shop and they said I have to replace the whole cylinder. ($342 work and parts). and thats without even checking. he just went in the car, saw it was stuck ,tried to take it out and thats it.
So what really should I do?
the car is automatic, is that really the problem? somthing with the stick not being enough "in" park?
Thanks in advance.
Old 12-24-2009, 11:59 AM
mustanger999 mustanger999 is offline
My cavalier did this. all I had to do was replace the ignition switch.
