91 buick Starter Enable Relay
Hello,
Can anyone tell me the exact location of the starter enable relay? 91 Park Ave Thanks! |
Re: 91 buick Starter Enable Relay
The relay is located under a black plastic cover in front of the firewall (relays are all lined up) I'm not sure the exact location of the relay, but I do know the colored wires which go to it. Check for the following color coded wires, and that's how you'll know you found the starter enable relay: 2 YELLOW wires, 1 BLACK/ YELLOW wire and 1 BLACK/ PINK wire. I'm sorry that I couldn't give you the exact location, but at least the relays simply slide off and back on again without needing any tools!
![]() http://www.cardomain.com/ride/2653398 1992 Buick Park Avenue (Daily driver) 2001 Saturn SL1 (gas saver)
The start enable relay is under drivers dash, above steering sector, behind IC panel. It is nearly impossible to get to from under the dash. If you remove the IC you will be able to see it. Look for a single relay with the colored wires Loekee described. Be sure to check the P/N switch first, much easier to get to. BTW, what is the problem?
Knowledge can be communicated, but not wisdom! ![]() ![]() |
Well , I'm having trouble w/ my vatts system in my 91 buick
so I decided to disable it . a retired wrencher told me to Cut the Black/Yellow wire coming from starter enabler relay and ground the relay side of the cut wire. I hoping this will disable the system. |
Why not just use a resistor bypass? It is much easier than tearing half of the dash apart to find the Black/yellow wire. That B/Y wire travels from the theft deterrent module (TDM) located under the passenger side of the dash, to the start enable relay behind the IC on the drivers side. I suppose if you wanted to go to that trouble to find the wire, that method would work.
If you want to do the bypass surgery, I will send you a PM with a schematic for the 91 PA and instructions on how to do the bypass under the steering column, without removing all the other paraphernalia. Good Luck!
Doesn't Vats also disable the fuel injectors?
So bypassing the starter enable would allow the starter to work but he needs to do the resistor bypass so the engine will start & run.
If the problem is only with the ignition switch key reader, or associated wiring, the bypass would allow the TDM to enable the injectors in addition to the start enable relay.
Hello , Thanks for the imfo ! I should check the gear selector switch . can you tell me its location and how to check? Thanks
Top, rear, driver’s sideside of transaxle & close to firewall. Check for 12v on the yellow wire and the pink wire when in P/N, and attempting to start.
