Old 02-24-2008, 03:37 PM
bhulbe00 bhulbe00 is offline
Exclamation 1991 buick lesabre oil filter
trying to do an oil change myself and i can not get the oil filter off of the car, does it turn to the left or to the right, is it like the usual lefty losey righty tighty. i can not get my oil filter tool in the space to remove it.
Old 02-24-2008, 04:25 PM
maxwedge maxwedge is offline
A990 racer
Re: 1991 buick lesabre oil filter
Welcome to AF, counterclockwise like a normal thread, should be able to get a strap type wrench on it.
Old 02-25-2008, 05:38 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Like maxwedge said, it is counterclockwise, and if you can't fit a filter strap wrench, then a good investment would be a "cap" type which fits onto a standard ratchet. Combine this with an extension and the job will be a lot less messy for you! If you cannot remove the filter with the wrench, then whoever last installed the filter overtightened it!
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 02-29-2008, 10:00 PM
gjhunter01 gjhunter01 is offline
Hi - One thing I have learned is to remove the oil filter when the engine is still warm. It comes off easier when the engine is warm and a lot harder once the engine has cooled off. If you still can't get it off, you can always punch a long screw driver through one side and out the other and using both hannds twist it off.
Old 02-29-2008, 10:36 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Red face Re: 1991 buick lesabre oil filter
Quick-Lube service centers are notorious for installing the filter without lubricating the gasket and then tighten the crap out of the filter. I think they do this on purpose, so if you try to chang your filter you will have a difficult time removing it. Most folks just give up when changing their on oil/filter because of this.
Old 03-01-2008, 06:00 PM
spinne1 spinne1 is offline
I have no trouble removing mine using large pliers, like these:
http://www.curbly.com/uploads/photos...lock_large.jpg
