Old 02-24-2008, 02:00 PM
toobs123 toobs123 is offline
wont start and no spark but cranks
98 intrigue 110000 miles
ran it out of gas one day
was able to fill it up and ran fine for a day came out the next day to start it and it wouldnt start
now the car will crank but wont start
pulled spark plugs to see if i was getting a spark and nothing
fuses are good
could it be a relay, crank sensor, ignition switch
I am at a lost and dont want to start replacing parts that dont need replacing
any help and advice would be great
Old 02-24-2008, 03:24 PM
Mickey#1 Mickey#1 is offline
Re: wont start and no spark but cranks
How did you check for spark? I pull a wire from one of the front plugs, insert a spare plug & rest the base of the plug against the head or block. Watch for spark while someone cranks over the engine. Repeat with the other two front cylinders to eliminate the possibility of a bad coil. The wires have to be on the rear plugs while doing this test.
If none of the front cylinders are sparking then check for 12 volts at the pink wire in the ICM wiring harness. Key has to be in run position. Let us know if you're not getting 12 volts.
If the pink wire has 12 volts then you pretty much have it narrowed down to ICM, crank sensor or the wiring between them. Best way to check ICM is by trying it on another car. I'd say we see 3 or 4 times more bad crank sensors than ICM's.
Old 02-25-2008, 09:07 PM
dtownfb dtownfb is offline
I guess the big question is whether or not you have any codes (Check Engine Light). Also if this happened the day after you ran out of gas, I would check to make sure the fuel pump and regulator are OK.
Old 02-26-2008, 02:14 PM
I tested for spark similar to the way you described i just didnt use a spare plug
Fuel pump comes on when I turn the key and there is fuel in the fuel rails
And there are no codes to be pulled
question though what is ICM an acronym for
Thanks again
Old 02-26-2008, 04:51 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
ICM is the ignition control module, its located underneath your coils on the left side of the engine if youre standing in front of the car looking at the engine.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 03-01-2008, 09:29 AM
I am getting 12 Volts at the ICM
going to replace to crank sensor today
will let you guys know if that is the problem
Old 03-01-2008, 11:02 AM
one question is the crank sensor located by the starter?
Old 03-01-2008, 11:35 AM
LittleHoov's Avatar
yes it is
Old 03-01-2008, 12:00 PM
i pulled the starter and did not see anything resembling the crank sensor
i also read somewhere that it is located by the harmonic balancer
Old 03-01-2008, 12:37 PM
LittleHoov's Avatar
ooooh crap!! dude im sorry, i didnt notice you had a 3.8, the ckps is behind the starter on the 3.5, and yes i do believe its behind the harmonic balancer on the 3.8. you might want to get yourself a basic repair manual for your car to at least tell you where stuff is at. Dont always really on forums, sometimes people can screw stuff up *cough* *cough*
Im not sure how hard it is on the 3.8, i know its a pretty easy procedure on the 3.5, seems like not so much on the 3.8
Old 03-02-2008, 04:32 PM
panzer dragoon panzer dragoon is offline
http://mykidz.net/GTP/CrankPosSensor.shtml (3800 GTP)
the Info is on this forum also somewhere
I don't like this situation since you have no OBD2 codes. What OBD2 scanner are you using?
I would actually recommend going to the dealer for the Tech2 scan or borrow someones Tech2. Right now you are really just guessing on these sensors.
Old 03-09-2008, 09:00 PM
was the crank sensor
problem fixed
thanks everyone
Old 03-10-2008, 01:05 AM
LittleHoov's Avatar
A bad crank sensor with no trouble codes, thats definetely somewhat unique.
Glad you got it fixed though, and Im sorry you had to pull the starter for no reason. I still feel like a heel when I read back through that.
