Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 02-24-2008, 11:20 AM
mrmusic88 mrmusic88 is offline
Fan blower not working on level 3???
The fan blower for the heat/ac does not work when you put the blower on level 3. A few years ago, a mechanic said it was a problem with an attenuator (I believe. I cannot remember for sure). He wiggled a small box and it worked again until recently. I don't know where the box was located, or what its technical name is. I would like to replace it. Can anyone help?
Old 02-29-2008, 04:14 PM
markqc markqc is offline
Re: Fan blower not working on level 3???
Sounds like it could be the blower resister located up behind the fan housing. If this is your problem and you want to change it, I found it is worth the extra 5 minutes to remove the fan housing and fan so that you can get your tools on the bolts holding it in. I think you will only need to remove the front bolt and only loosen the rear two, and you can slide the unit out.
Good luck.
Mark
Old 03-09-2008, 01:59 PM
Question Re: Fan blower not working on level 3???
Thanks. I am, not very experienced with this car, so could you give a "for dummies" explanation of where the blower housing is located?
Old 03-09-2008, 07:34 PM
The blower motor is located under the glove box.(where the passenger's feet would be) It's a little awkward to get at like everything else on these vans. I believe there are 3 bolts holding the motor in place. Remove the wire connectors to remove the motor. There are 3 bolts holding the blower resistor in place. You only need to loosen the back two and remove only the front bolt and the unit should slide out.
Good luck,
Mark
Old 03-12-2008, 09:06 PM
Zackor2 Zackor2 is offline
I had same problem, and yes it is hard to get at, but can be done. Remove motor, then resistor pack. I was able to build up a new solder bead on the printed circuit board, with a good soldering iron. Fixed problem about a year ago, and has not come back.
Old 03-12-2008, 10:08 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Here's a link to a diagram of where the resistor is located:http://autorepair.about.com/library/a/1h/bl251h.htm
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
