| Performance Anything you ever wanted to know about boosting the performance of your Cavalier. |
I am not so much interested in increasing HP as I am in increasing MPG. I have seen all the hype on chips, modules, etc that trick the IAT into thinking the air is colder than it is so the ECU will increase the gas input. I am wondering if I PREHEAT the air passing by the IAT, will this cause the ECU to decrease the amount of gas input, and if I do that what kinds of problems will I encounter if any?
Thanks in advance!!!
Re: Preheating intake air
i dont care what anyone says, i believe that intakes decrease gas milage. They arent going to help it.
more air = more gas. simply put
![]() 2000 Pontiac Sunfire SE Quote:
rags, thats a nice thought but it wont improve your mpg by any means, how did you plan on heating the air anyways???
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM, 1981 Fairmont 6cyl 3 speed 1978 Ford Ranchero GT 302 with a few goodies |
Do some research on your question......google it and shit...Cooler air is what you are wanting...if you got a CAI and a proper tune you would see increased miliage. Most people see a decrease though because the "sound: makes them think they are speed racer or their a/f ratio is off. Wanna get better fuel economy then get a car that was meant for that. find yourself a CRX or a 1.0 3 cylinder geo metro...that shall help you out
I thought if the IAT sends data to the ECU for the gas to air ratio when cold to add more gas, then by passing warmer air over the sensor it would lean out the mixture. However I will be the first to admit I know very little to nothing about how the system works. Thanks
PS. By the way I did Google it and was unable to find information on it. Only found info on getting colder air added. Chips, Modules, Turbonator etc.Thanks |
You're cover over the exhaust is a heater stove that was used on carbureted engines for cold weather conditions. Your tube off the exhaust, EGR, which needs to be regulated, can't be at all times, especially idle. The IAT is primarily only used at start up. And a lean mixture = burnt valves and pistons. |
If you're trying to increase mileage, there are only a few true ways:
1-alignment and tires, proper size, pressure, tread and regular rotation. 2-remove excess weight, the trunk is for taking items from point a to point b, not for indefinate storage. 3-routine maintnance of the igntion and fuel systems 4-curbing and motioring personal driving habits Just to name a few for idea. Today's vehicles diagnostic systems are only as good as they were designed to be, and OBD II can limitly adapt as neccessary. If the vehicle is not acheiving it's rated mileage, something of the above list is not right. I've even had my carbureted cars exceed their ratings with nothing more than religous maintenance.
Based on the MPG you've observed already, it's within 90%.not bad for a start, assuming it's a used purchase. |
