Hello, I am looking for a little advice here please. My son and his grandfather just rebuilt a 1994 Chevy 1/2 ton 4 x 4. Everything is new but the motor(350), which ran fine. The problem is when the motor temp hits 160 degrees the oil pressure begins to drop from 40 pounds all the way to 15/20 pounds. The engine temp is fine and everything else seems ok, just the oil pressure. I am wondering if it could be the factory gauge, or maybe the oil (10w/40) is too heavy/light? Or is it the worst case scenario, a failing oil pump? I should mention, I just replaced the oil pressure sending unit and the same scenario exists.
Re: Oil pressure drops as engine gets warm
Welcome Aboard!
Even if the gauge is correct, that oil pressure is just fine. The general rule for a SBC is that it requires 10 PSI for every 1,000 RPM. At an 800 RPM idle, 15 is just fine. If you are really concerned, drain the oil and replace the filter. Install any oil filter you want so long as it reads "Wix" or "Hastings" or "Delco" (more specifically, anything that doesn't read "Fram") and add the appropriate volume of 10W30 Mobil 1 or Amsoil. The viscosity index of a PAO synthetic is a lot better than that of a mineral oil with the same base viscosity range.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
The strange thing is that when you start off on the road it reads 40 and as your driving you can actually watch the pressure drop. What could cause this??? And thank you in advance for the posts, this site is incredible.
My suggestion is to run 15w50 Mobil 1 or Amsoil in it, change your filter to the non-Fram of your choice, run it for a bit and see what happens. You're likely to see the oil turn black pretty quick as PAO synthetic is highly detergent and works well at removing sludge.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
after thinking about this I now would get a gauge and check the oil pressure ... when cold should be 60-80psi then at normal operating temp 30-45psi....possible dash reading is off by 20psi.....this could be just oil sender off...... |
Thanks to all that replied, your help was immeasurable!!!
What I did was change the oil and put in an additive (Lucas engine oil treatment) I upped the oil from 10-30 to 10-40 Castrol GTX for high mileage engines with a special anti-sludge formula. Then I changed the filter to a high mileage filter(not fram). Immediately the oil pressure went up to 45 psi. When it reached 160 it never dropped below 38 psi and has been steady since then. I told my son to keep an eye on it and if it drops down again, change the oil by repeating what we had just done. Its cheaper to do a 25 dollar oil change than it is to swap out a block. Thanks again to all!!! You guys are great!! Tony N. |
Good deal, but please keep in mind that a 10w40 is about the worst oil grade you can put in it. If you want to run Castrol, 20w50 is not a bad oil to run, but keep in mind that if that engine has a flat tappet cam (which were still used even in '94 on trucks) that you will need to put in an additive which contains ZDDP (zinc dialkyl dithio phosphate) to keep the lobes on the cam from going away.
