Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 02-23-2008, 07:01 PM
Idagal Idagal is offline
Question No spark no start
The plenum on our 98 Bonniville series2 went out and it filled the cylinders with antifreeze. We repaired that and drained the cylinders. Now the car will not start it has no spark. We replaced the Crank sensor. Still no spark.we replaced the electric ignition module. Still no spark. Should there be power to one of the wires on the module? Any help or ideas would be greatly appriciated
Thanks in advance
Idagal
Old 02-23-2008, 10:11 PM
Mickey#1 Mickey#1 is offline
Re: No spark no start
The pink (pink/black some years) wire should have 12 volts while the key is on.
Old 02-24-2008, 06:47 PM
ok no spark there now what?
Old 02-24-2008, 06:52 PM
If you don't have 12 volts at the pink wire then check all the fuses on the passenger side.
Edit - #6 under the dash on passenger side.
Old 02-29-2008, 06:55 AM
Thumbs up Re: No spark no start
Was finially able to get back to the problem. The fuse ws the culprit
Thanks so much
Old 02-29-2008, 10:51 AM
Glad you got her going & thanks for letting us know. It's sure nice to hear when a problem gets resolved.
