Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 02-23-2008, 05:30 PM
krazykat1963 krazykat1963 is offline
Unhappy turn signal flasher
Having trouble with my 1991 Pontiac Bonneville LE turn signals. They just stopped working. The hazards work so does not appear to be any bulbs. Tried the fuse and no luck. Assuming it is the turn signal flasher. Bought one but cannot find anything that is the same anywhere under the steering column or dashboard. Only piece that looks similar is longer and on a bracket. Tried several parts stores and they all indicate that I have purchased the right flasher. Any help from anyone would be greatly appreciated!
Old 02-25-2008, 03:31 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: turn signal flasher
IIRC, the turn signal flasher is mounted by a clip on the back side of the black plastic panel, near the fuse block.
