Old 02-23-2008, 05:07 PM
bernie1 bernie1 is offline
speedo & oil gauge go to zero when accel
Hi
this is my first post , I have a 1988 dodge caravan 3.0 V-6 when I accelerate the speedo& the oil gauge goes to zero when I take my foot off the acelerator pedal it go back to where they were . It started with just the oil gauge but now has gone to include te speedo . The other gages & tach work find. Anybody out there run across this ? If so what is the fix I have moved harnesses around did not change problem
Old 02-24-2008, 02:02 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: speedo & oil gauge go to zero when accel
Wow. This is an odd one. I've never worked on a gen 1 Caravan so I can only talk in general terms. Can't see a single sensor causing both. I'd guess it's either wiring in a common bundle or the instrument cluster circuit board. If you haven't yet you might try following the oil pressure sender wiring through it's bundle to the firewall connection. Maybe it and the output speed sensor wiring have chaffed at the same point. Could be a bad connection at the instrument cluster or solder joints on the cluster circuit board if equipped. Beyond that, not a clue. Hope someone has seen this problem and chimes in with a fix for you.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 06-26-2008, 04:35 PM
brocsbar brocsbar is offline
many caravans have this problem and if you let it go your guages and spedo etc wont work. take out the 4 screws that hold on the a/c stuff and unplug it and inspect for a burnt terminal I JUST did one 5 min ago. Clean it up and plug back in or get one from the junkyard
