Go Back   Automotive Forums Car Chat > Eagle > Vision
Old 02-23-2008, 05:03 PM
mparmley mparmley is offline
95 Vision TSI Keeps overheating!!!!
I have a 95 vision with 3.5l engine. Recently replaced water pump, tesioner and a pulley. (water pump was leaking). Also replaced thermostat and radiator cap. Now i cant keep it from overheating. Temp overheats then purges coolant out of the overflow on the tank. I am out of ideas. There is no coolant in the engine oil and i do not see any leaks anywhere. Cooling fans seem to work fine and i have nice warm heat from the vents. Please help.
Thanks
mike.
Old 02-26-2008, 09:25 PM
Re: 95 Vision TSI Keeps overheating!!!!
Somebody??? Anybody???? I have already sunk just about $700 into the work i had done recently dont really want to spend too much more on a car that has almost 170,000 miles on it. Thanks
Old 04-09-2008, 07:35 PM
harvestsmiles harvestsmiles is offline
Question Re: 95 Vision TSI Keeps overheating!!!!
Did you find a solution to that problem?
On my way home tonight I stopped at a light and had a bunch of steam come out from the hood and my temp gauge was all the way up. I pulled over to let it cool. Luckily I was close to home. I filled the overflow tank up and I didn't see any more leaking. What are the first things I should check?
