A/C compressor donīt engage
Olds 98 Regency 1991 with 62.000ml on it
Checked all A/C fuses. Grabed in dash self diagnoses code # 138. The air comes ok in all the vents but the compressor clutch still off. Any help or tip will be welcome. Malachias (BRAZIL)
Re: A/C compressor donīt engage
Low freon can cause this for starters and/or temps below 40 which is normal.
Dear Maxwedge: Thanks for your quick replay.
The low freon code is 66 or 166. The temp here i Brasil is always hot. The code that I got is 138 (Serial data line failure with PCM). Do you know what it means? Thanks a lot in advance. Malachias |
This usually means the Pcm has lost comm. with the BCM
Dear Maxwedge:
Is the Pcm a Programmer module and a BCM a Body Control Module? If yes, what you advise me to do? Thanks Malachias (BRAZIL)
Confirm the system is fully charged using an A/c gage set. Pcm is the main controller not the programmer. ( Powertrain control module)
Dear Maxwedge:
You was right; even I had grab a 138 code # in the self diagnose A/C display I followed your advise and did a Freon level recheck again (Low freon code is 66) and found my sistem with a half of charge wiht a litlle leakeage at the high pressure valve. I fixed the valve, recharge the Freon and the cluntch compressor start to work. No more headake problem solved. Thanks a lot for yours helpfull tips. Malachias (Brazil)
You are welcome.
