water pump hoses
I am replacing my water pump on 1990 E250/ 5.8 . I forgot which hose is heater and which is the bypass connection on pump?
Re: water pump hoses
Normally the heater goes to the heater,the bypass is a short hose that goes to the front of the engine.
5.0L and 5.8L Engines
1989-95 MODELS See Figures 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 and 11
Fig. 1: Remove the cooling fan-to-clutch bolts Fig. 2: Remove the clutch and fan assembly from the engine compartment Fig. 3: Remove the water pump pulley
Fig. 4: Loosen the heater hose and bypass hose clamps ... Fig. 5: ... and disconnect the hoses from the pump Fig. 6: Loosen the lower radiator hose clamp Fig. 7: Disconnect the radiator hose from the water pump Fig. 8: Loosen the A/C compressor/power steering pump bracket-to-water pump retainers Fig. 9: Slide the bracket forward to disengage it from the studs on the pump Fig. 10: Loosen the water pump mounting bolts Fig. 11: Remove the water pump from the engine compartment To install:
