Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-23-2008, 11:39 AM
paulfischer paulfischer is offline
timing chain
04 suburban, 5.3 flex fuel, 62,000 miles.
Just wondering if I have to replace timing chain as part of preventive maintainace? Truck is running fine. Or just replace when needed??
Thanks
Paul
Old 02-23-2008, 02:48 PM
SLJ2137694 SLJ2137694 is offline
Re: timing chain
Replace as needed, it should run a long time!
Retired and Loving It!!! 33 years with General Motors Product Service Engineering. A.S.E. Certified. You can fix ignorant but stupid will be a real challenge!
Old 02-23-2008, 04:47 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: timing chain
I have 168, 159, and 189 thousand miles on my timing chains, still the originals and no problems (except for the PLASTIC tensioner and guides on my Pontiac ), but yours should go several hundred thousand easily.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
