Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-22-2008, 05:03 PM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
Air/Fuel Gauge Install
Does anyone have pics or tips on instaling an Autometer Air/Fuel Gauge? Its on a 2g, you just connnect the wire to the o2 wire right?
97' Eclipse RS 5 Speed 420A
Under The Hood:
Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires
Interior:
Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout
*GOAL* - Prove Him Wrong
Originally Posted by UnderEstimate Me
I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs.
Old 02-22-2008, 05:34 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: Air/Fuel Gauge Install
IIRC, NO! you have to tap into the wiring to the ECU harness, i cant remeber what ones, but i do remeber tapping my turbo timer in their for A/F readings... and i cant imagine a A/F gauge being any different seeing as how they do the same thing as far as that aspect!
Old 02-22-2008, 05:43 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
http://www.2gnt.com/?d=1997_ECU
Yea you connect to the wire at the ECU. Not sure if you can see that page, but your going to tap into the white wire with a black strip. You would be better of installing JAW though. More accurate.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-22-2008, 08:30 PM
What is JAW? I am looking at having some more specs of my car in front of me so i know whats going on under the hood. I was looking to get a gauge for the Air/Fuel, Volts, Oil Preassure... Is there something out there that isn't extremely expensive that would be better? Thanks
Under The Hood:
Interior:
Old 02-22-2008, 11:45 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
A narrowband AF guage isnt something you want then, they arent good for much more than a light show. If you really want to know what your AF ratio is, get yourself a wideband. Check the writeups and tech articles, SilverEclipse had one in there about a DIY wideband that all said and done with a display is like $130 if you assemble it IIRC. Also, oil pressure is a good thing to have, but I honestly dont think the volt meter is worth the money.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 02-22-2008, 11:52 PM
Black99GST's Avatar
i have had extremely good luck with my "light show" it is very close to the readings that would be recived from a wideband (i did my own little test at the local dyno) however, wideband is still on my "to do" list... as far a functional gauges on a N/T (as far a function on an N/T goes...) i would probably go with a wideband set up, then a data logger, and something for fuel tuning... (not really all gauges, but you can watch whats going on, and also change some aspects if problems arise...
Old 02-23-2008, 11:13 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Narrowband is only somewhat accurate at WOT since that's the only time you get an actual reading that's not all over the charts. Ricky, you don't need a wideband as you're not even close to that. A/F gauges are pointless then also.
Of course unless you like lights...
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-25-2008, 08:29 AM
No light show?
Under The Hood:
Interior:
Old 02-25-2008, 09:05 AM
Black99GST's Avatar
like i said, mine works pretty damn good for a narrow band...
Old 02-26-2008, 09:00 PM
Yea i think ill give it a shot... I have this thing with gauges and lights, so ill be happy, lol.
Under The Hood:
Interior:
