Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 02-22-2008, 02:10 PM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
Egr Delete???
that pipe that comes out the front top of the intake manifold, is that the egr? can you delete that, its ugly.
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm summit throttle body
85mm bbk ssi intake
fast fuel rails
30lb ford racing injectors
spohn strut bar
msd ignition coils
msd 8.5mm spark plug wires
edelbrock shorty headers
upgrade cam/ port and polished heads
SMG dyno tuned ( 375 rear wheel hp )
magnaflow cat back
slp y pipe
umi bolt on subframe connectors
umi rear control arms
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 02-24-2008, 07:20 PM
89Firebird2.8's Avatar
89Firebird2.8 89Firebird2.8 is offline
Re: Egr Delete???
Not if you want to pass smog. Some say that our engines were designed with EGR in mind and run like crap without them anyway.
2012 Ford Fusion SE 3.0 V6
-SOLD- 1992 Lexus LS400 4.0L V8
-SOLD-1989 Firebird 2.8l V6 Red and White w/flames. Stock. Daily Driver.
Old 02-24-2008, 08:57 PM
poormillionaire2 poormillionaire2 is offline
Re: Egr Delete???
If its that tube that pops out right after the TB opening, then yes, you can delete it. You will just have to plug the hole and the rest of the EGR connections. You can buy EGR block-off plates. The only thing is your PCM will throw a code. It won't affect driving or anything, you will just have an SES light until you get it tuned out.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 03-03-2008, 10:31 PM
Re: Egr Delete???
Does it have much of a positive effect on the vehicle?
Old 03-04-2008, 07:50 AM
Re: Egr Delete???
Not performance-wise. It just cleans up the engine bay a little. The EGR shuts off at WOT and that's why there are no gains in TQ or HP when it is deleted.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 03-04-2008, 10:11 AM
demon9766 demon9766 is offline
Send a message via Yahoo to demon9766
Re: Egr Delete???
the egr also helps cool the combustion chamber , on cars that are designed with and egr systems removing it may cause detonation and that can cause burnt or warped valves and holes in cast pistons.
This is what 500 plus hp looks like.CNC ported AFRHEADS WITH 2.02 INT 1.60EXH,210 intake runners 74cc chambers, 750 speed demon carb,weiand intake,comp cams 292 with .501/.501 lift ,4340 forged crank,eagle H-beam rods duroshield bearings,KB forged 10 1/2:1 pistons,headers with 1 3/4 primaries ,MSD 6AL,comp cams pro mag1.6 rockers,holley blue pro-series pumps,MSD billet distributor.All stuffed into a 355.[img][/img]
Old 03-04-2008, 10:13 AM
stieh2000's Avatar
stieh2000 stieh2000 is offline
Re: Egr Delete???
Its there basically to enhance emissions, and to some extent economy and/or efficiency.
Apperance Mods: Firebird wheels of mysterious origin , Floormats , and a quarter sized dent behind the passenger door from a TV I dropped!
Old 03-04-2008, 06:14 PM
gorgepr gorgepr is offline
Re: Egr Delete???
of course you can delete it, headers do no come with egr line, thats the first thing I do to all of my cars and honestly doesnt affect or damages anything
Old 03-04-2008, 06:21 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: Egr Delete???
Actually headers do come with egr fittings but you can order them with or without. I don't have any egr related components on my car but that's only because it wasn't working properly.
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 03-04-2008, 07:43 PM
GreyGoose006 GreyGoose006 is offline
Re: Egr Delete???
mines gone
thats how i got it
