Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-22-2008, 11:51 AM
churrieta churrieta is offline
'01 Grand Cherokee Oil Recommendations
Syntetic oil vs regular oil, what would you recommend?
Old 02-23-2008, 05:49 AM
Bob D. Bob D. is offline
Re: '01 Grand Cherokee Oil Recommendations
From new, full synthetic oil would be my choice. For a '01 with xx miles already on it either is fine. If you choose synthetic, there is a general consensus that it can cause oil leaks in higher mileage engines.
Old 02-23-2008, 09:31 AM
Thanks Bob. I have 84,000 miles on it.
I'm on the fence on what to do with it.
Old 02-23-2008, 10:57 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
I had a 2004 that had 86k when I got it. I switched over to synthetic, and had some seepage around the seals, but they closed up after awhile and it didn't leak after that.
I did some research on it, and apparently what happens is that the regular oil had crusted around the seal, and formed a seal out of the crust. Then, as the synthetic carried away the crust, the seal was exposed, and since it hadn't been lubricated, leaked a bit until it softened up.
If there's too many miles on, then the seal doesn't soften up and the leak stays, which I believe was Bob D's point.
That said, I've never had a problem using regular oil with numerous cars, and would say that it works just fine if you change it. But I did get about 1-2 mpg better with the synthetic oil.
Some synthetics say you can go with a longer change interval, check out bobistheoilguy.com for a lot of information on oil.
Overall, IMO synthetic oil will allow your engine to stay cleaner in the long run.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-24-2008, 12:45 AM
-Then, as the synthetic carried away the crust, the seal was exposed, and since it hadn't been lubricated, leaked a bit until it softened up.
If there's too many miles on, then the seal doesn't soften up and the leak stays.
That's the best explanation I've heard so far.
fredjacksonsan, your link doesn't work but I think you were pointing here:
www.bobistheoilguy.com
Old 02-24-2008, 07:28 AM
Yup...don't know why that link didn't work.....
Old 02-26-2008, 10:16 PM
Thanks for all the help. I am going to go with the synthetic oil.
Old 02-27-2008, 07:47 AM
Cool; hope the site was of some help.
You may also want to check out Auto RX, I used it on my '00 and it work as advertised.
Enjoy!
