Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 02-22-2008, 01:44 AM
craaze1988 craaze1988 is offline
I need help taking off my door panel
I have a 2000 chevy malibu and i try to take the door panel off to replace the speakers i took the screws out and it seems to be stuck i dont wanna break the clips how can i take it off with out breaking the clips
Old 02-22-2008, 05:39 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: I need help taking off my door panel
You need a door panel removal tool. Looks like a bent, thick, putty knife with a slot in the middle. Otherwise a couple flat screwdrivers will usually do the trick.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-23-2008, 05:31 AM
I tryed that but the panel just dont wanna budge what so ever and i don't wanna break the clips
Old 02-23-2008, 05:01 PM
westsider westsider is offline
Did you make sure to remove the door handle bezel, window regulator handle, power window switch, and door trim handle screws, if any of these are equipped on your car.
Old 01-09-2009, 03:30 PM
Mc Lovin Mc Lovin is offline
i need help removing the window regulator handle on my chevy malibu 2000 does any one know how to remove it ???????
Old 01-09-2009, 06:34 PM
rhandwor rhandwor is offline
http://www.kwmuth.com/techsupport/pdfs/21001330.pdf This is for a Tahoe but should be close enough.
