Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 02-22-2008, 12:04 AM
petebh petebh is offline
Angry 1989 olds touring sedan some times wont start
This car is driving me nuts .I put a reman.engine and had tranny rebuilt,replaced every sensor and put a new fuel pump in. My car only seems to want to start when i put the ignition to the on position 2-3 times then it will start.Took it to the dealers and had it there for a month and every day it was there it started right up.Also if i dont prime the ignition like i do it takes a lot of cranking to get it started. A couple times it left me stranded.I changed the crank and cam sensor,tps senser fuel pump relay,oil pressure switch. Another thing is that once i get it started i can turn it off and on all day as if there were no problems. Its just when it sits for a while. Please help i have put a lot of money in this car and its the only problem im having. Thank you!!!!!!
Old 02-22-2008, 02:45 PM
maxwedge maxwedge is offline
A990 racer
Re: 1989 olds touring sedan some times wont start
Welcome to AF, get a scannner on it cold and check the coolant temp sensor readings, also get a FP gage on it and see if the pump primes. Change the fuel filter also.
Old 02-28-2008, 01:28 PM
[quote=maxwedge]Welcome to AF, get a scannner on it cold and check the coolant temp sensor readings, also get a FP gage on it and see if the pump primes. Change the fuel filter also.[/ thank you i will try this. also i think i forgot to mention i changed fuel pump twice already quote]
Old 02-28-2008, 01:32 PM
Thank you i will try this . I think i forgot to mention that i changed the fuel pump twice already.Could it be the tps sensor sticking or something at start up?
Old 02-28-2008, 03:17 PM
A990 racer
I don't think so.
