Old 02-21-2008, 04:52 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Question D15B1 block D16Y7 head swap ?
I know a guy who blew up his engine (rod) in his '88-'91 Si. He has a D15B1 '88-'91 STD block with a bad head. He also has a '98 Civic with a D16Y7, bad short block. He isn't sure if the Si head is any good, so he might have to use the Y7 head on the STD block. Obviously the Si head would be a piece of cake, but I'm lost on the Y7 thing. Is putting the Si intake manifold going to require any fabrication? What about the distributor, which one should he use? I'm assuming that the Si distributor won't just bolt right up to the Y7 head, or is that a poor assumption? I know the '92-'95 B7 distributor bolts right up to the Y7 head. I've tried searching, and will continue to, I just seem to have lost my link to a 4th gen block to 6th gen head swap. Any help is greatly appreciated.
Old 02-21-2008, 05:21 PM
CivicSpoon's Avatar
There is no Spoon
Re: D15B1 block D16Y7 head swap ?
Ok. From searching, it seems as though the stock distributor will in fact fit fine with the Y7 head. It also seems as though the intake manifold will fit fine as well. Can anyone confirm or deny this??? Please...
Old 02-21-2008, 05:49 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
it definately will mabey work
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 02-21-2008, 06:04 PM
CivicSpoon's Avatar
There is no Spoon
haha, thanks
Old 02-21-2008, 09:11 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Itll fit. the z6 is the one with the weird dizzy. The head will fit as well.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 02-21-2008, 09:51 PM
CivicSpoon's Avatar
There is no Spoon
bad ass, thanks for the help
Old 05-19-2015, 12:38 PM
ramonelias ramonelias is offline
Hi, I want to make that change block d15b1 and head D16Y7, also put injection that would need, as I have ECU, intake, distributor, wiring but going from the ECU to the engine, not the interior of the car as you would that Connecting up of obd0 with obd2b .... I do not speak English
