Old 02-21-2008, 04:04 PM
Rinkerxx Rinkerxx is offline
Help me please!
My check engine light has been coming on and going off for the last about 6 months. Now it will come on and stay on for 1-3 days then go off for a few weeks then comes back on. Theres no real way of telling when its going to come on or go off. So I found out the service engine code ws P1340 which means camshaft position sensor B circuit malfunction. Now I have no idea what I do to fix this? Does anyone know what it means? or if its a big issue?
Old 02-21-2008, 04:09 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: Help me please!
New camshaft position sensor and o-ring.
i wouldn't embark on it unless you know a fair bit about mechanics and have the tools. not particularly hard, but you go to be careful.
Seatbelts Saved My Life
Old 02-21-2008, 04:15 PM
Re: Help me please!
I know a bit about mechanics but I don't have any tools I just moved and got this light.. Shows my luck. Would it be expensive to get someone to do it?
Old 02-21-2008, 04:23 PM
UncleBob UncleBob is offline
AF -Advisor
Re: Help me please!
let me guess.....nissan 3.5L engine.
Very common problem. Takes a 10mm socket and about 30 seconds to replace it.
if its not a nissan 3.5L engine, it might not be the sensor itself is failing. Many VVT engines set that code when the VVT solenoid is gummed up from not changing your oil often enough
As always, it really helps if you tell us what vehicle we're talking about.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 02-21-2008, 04:26 PM
Re: Help me please!
actually its a 98 Ford Zx2 2.0L Vtec. the motor was swapped to the vtec.
Old 02-21-2008, 04:35 PM
Re: Help me please!
i'm guessing you mean Zetec?
Old 02-21-2008, 04:39 PM
Re: Help me please!
Sorry yes I got honda on my mind for some reason. Anyways either of you know how much It would cost? Im actually trying to sell the car and I need this fixed.
Old 02-21-2008, 05:10 PM
AF -Advisor
Re: Help me please!
yup, usually dirty oil
We call those codes the "change your oil, stupid" code.
Some engine cleaner often helps, such as seafoam.
