Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 02-21-2008, 02:53 PM
Naomi404 Naomi404 is offline
1997 Tahoe heating issue
I have a 1997 Chevrolet Tahoe,and the heat doesn't work..I have flushed the radiator,changed the thermostat,put in a new heater coil,a new heater control switch. What could possibly be wrong?
Old 02-21-2008, 04:07 PM
777stickman 777stickman is offline
Re: 1997 Tahoe heating issue
Most likely the temp control door since you've replaced almost everything else.
The temp door is electrically controlled by the settings on the dash panel.
So either the door is jambed, the motor is bad or the wiring to it is bad.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 02-21-2008, 04:15 PM
j cAT j cAT is offline
did you or someone else replace these parts ??
does the heater blower work... ? are the heater hoses both hot ????when filling radiator with coolant did you leave fill cap off till the engine came to operating temp??????????
Old 02-28-2008, 07:53 AM
jonnik jonnik is offline
There is a heater valve under the air filter housing-check to see that the cable controlling the valve is working.
Old 02-28-2008, 05:00 PM
NoEcm NoEcm is offline
On a 1997 the heater valve is vacuum controlled. Here is what the part looks like:
http://www.partsamerica.com/ProductD...pe=394&PTSet=A
This is what controls the flow of heated water to your heater core.
Heated water exits the engine block and goes to the heater valve. If the heater valve is closed the hot water is looped back to the engine block. If the heater valve is open, the hot water is allowed to flow through to the heater valve to the heater core.
If you are getting hot water flowing through the heater core and the tempature control door is open, you'll have heat in the cabin.
Troubleshooting should be fairly simple from here.
Old 02-28-2008, 06:02 PM
THIS PERSON NEVER REPLIED TO ANY POSTS !
