97 Aurora won't start when its cold outside
I have this 97 Aurora that starts okay when it is say 40 degrees or warmer outside. However, when the temp falls to say 30 or 20, it will just spin and spin. Sometimes, when it does start after turning over for 3 minutes in 20 second shots, it will be flooded and smoke hard. Also, before it finally does start, it will be backfiring into the air box. Sort of a muffled popping sound. When it finally starts, it runs fine and will start all day just fine as long as the motor doesn't get too cold. But overnight at 25 degrees, and it is almost a no start. In fact, it has been towed home recently since it wouldn't start after an 8 hour shift on a cold night. How can the car start fine in warm weather, run great, but start so bad when it gets cold out? Any ideas/help would be great. I mean, I don't want to keep cranking this in excess. The starter will go and then.....well, we all know about that so I won't mention it.
Re: 97 Aurora won't start when its cold outside
Better get a fuel pressure gauge on it-- it takes extra fuel to start an engine when its colder out. If you don't have adequate fuel pressure- or borderline minimum pressure- will have trouble starting. it always takes more pressure to start the car, than it does while it is running. If your fuel pump is weak it will show itself on colder mornings first- then eventually it will fail on warmer days...the pressure check will tell you whats going on....
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
![]() Thanks for the input and I get a pressure gauge on it and see if maybe it is lacking in the pump dept. New pumps aren't always good. |
